honda civic defroster help
Discussion in 'General Automotive' started by vtragweed, Dec 30, 2010.
  1. Dec 30, 2010 at 6:40 AM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    my wife has an 03' honda civic for her commuter car. every morning i go out and start it and let it warm up for about 15 minutes. the engine will be completely warm but wont defrost the windshield until the car is moving. any ideas whats going on?
  2. Dec 30, 2010 at 7:11 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Is the heat coming out of the vents warm? Keep in mind the heater gets its heat from the coolant of the engine running across the heater core. You usually won't get to full operating/optimum temp until you drive it a little and put then engine under some load to create heat.
  3. Dec 30, 2010 at 7:16 AM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    the air coming out is somewhere between warm and cold, it never had a problem before this year and always defrosted just fine
  4. Dec 30, 2010 at 7:38 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    A cheap test would be to replace the thermostat. you might not be noticing any issues (other than the defrosting) because of the outide temp. But if the thermostat isn't opening when it should it could be preventing the hot coolant from getting to the heater core.
  5. Dec 30, 2010 at 7:39 AM
    macgyver
    Brad
    Canton, GA
    Agreed, A New thermostat should cost you less than $20 and is easy to replace.
  6. Dec 30, 2010 at 7:54 AM
    vtragweed
    Willie
    VA
    08 2.7 SR5 Debadged
    good deal ill try that first
  7. Dec 30, 2010 at 7:56 AM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    a new thermo sounds like its needed. when i did my integra.. it was like 7 bucks but a pain to get to. is the civic a SOHC or DOHC? if its a B series engine. its going to be tough to get to lol. good luck.
  8. Dec 30, 2010 at 7:58 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    whats a honda civic?? :notsure:
  9. Dec 31, 2010 at 11:01 PM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    Before you go throwing thermostats into the vehicle....
    -Check the coolant level in the radiator. If it's low, add some fluid.
    Also a good time to determine if you have a possible coolant leak.
    -Investigate your radiator cap a little more closely. Have it tested to see if it's holding pressure.
  10. Jan 1, 2011 at 1:29 PM
    macgyver
    Brad
    Canton, GA
    This too...I once had a cooling issue in my old accord. I turned out to be a bad radiator cap which was also causing air to get in the system. Replaced the cap and bled the system and it was good again.
