Honda Foreman squeek!
Discussion in 'All Terrain Vehicles' started by hillbillynwv, Aug 20, 2008.
  1. Aug 20, 2008 at 10:22 AM
    hillbillynwv
    hillbillynwv [OP] Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I have a 2003 Honda Foreman S 4x4 with 1400 miles. I have a front end squeek and can't find where it is coming from. I know what side it's coming from but can't determine if it's from the shock, bushing in the a-arm, or elsewhere. The sound drives me nuts and just spraying Armor-All on everything rubber in that area doesn't help. If someone here has had a similar problem and found out what it was and how you fixed it please share your info.
  2. Aug 20, 2008 at 10:28 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I suggest just taking it apart and greasing your bearings. Its probably time for that anyway.
  3. Aug 20, 2008 at 10:28 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Its probably the Brakes. The front and back are drum and one little piece of sand in there will cause that squeek.. I have an 02 foreman ES and I get the same thing...very irratating to say the least. Go thru some deep water, or a big mud hole - that usually is how I solve my problem. Riding the front brakes alittle bit or a quick stop helps sometimes too. Good luck.
  4. Aug 20, 2008 at 10:32 AM
    dually
    dually Low and slow
    If it is the brakes, just inspect the pads. Im not a quad person by any means, and have never worked on a utility. But i know my way around a bike quite well...
  5. Aug 20, 2008 at 11:00 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if it turns out to not be the brakes squeaking.,..........spray some pb blaster on the shocks, and on the a-arm bushings and let it soak in the bushings sleeves. should do the trick. if you dont wanna use pb blaster.....get some good silicone spray........dont use wd-40.
  6. Aug 20, 2008 at 7:33 PM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    Its the shocks...Same thing happened to my ridin buddy...He greased the hell out of them....worked like a charm...
    I think he used haynes spray...
    Same bike as yours too...Must be a honda thing...
  7. Nov 15, 2008 at 5:42 PM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    It's the shocks.
    I had the same problem.
    Took them off the bike, sprayed them with WD-40 even turned them upside down and sprayed down the tube.
    Much better :thumbsup:
  8. Dec 15, 2008 at 7:22 PM
    PaulVthe3
    PaulVthe3 Well-Known Member
    sweet! My lifted rancher does the same thing my daughter calls it squeaker!
  9. Oct 9, 2009 at 4:49 PM
    Sideways
    Maryland
    05 TRD dbl cab
    Should have taken tacomaman's advice an not used WD-40, the squeek is comming back on my Foreman.
    Will have to find some PB blaster and try that
  10. Oct 9, 2009 at 4:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    be sure to pressure wash it good first......or the dirt/dust will stay trapped in there.
