Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Dec 5, 2018 at 7:01 AM
    #6201
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Sorry if I missed it earlier - did you do counter top laminate for the top of the tray and drawer faces?
  2. Dec 5, 2018 at 7:03 AM
    #6202
    campvibes
    campvibes Well-Known Member
    Tim
    CA
    My thoughts exactly now. But the coin it's a big investment. Now I am in a spot where I can afford it
    slowboater, butters_, tonered and 2 others like this.
  3. Dec 5, 2018 at 8:05 AM
    #6203
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Slick setup. What does that weigh? Most homebilt setups, I’ve encountered typically weigh 250-350lbs with nothing in them. One of the reasons i’ve steered clear.
    If any of you dclb peeps want a usefdecked system drop me a pm, seitching my setup out again
    JLink likes this.
  4. Dec 5, 2018 at 8:13 AM
    #6204
    gman36
    gman36 Well-Known Member
    San Diego, CA
    2018 Cement DCSB OR
    Correct, its a black formica laminate.
    My guess is 250, the slides alone weigh about 80 for both pairs.
  5. Dec 5, 2018 at 8:37 AM
    #6205
    aaen
    Northern Alberta
    What type of slides , Are they similar to the ones you see on fridges? Only reason I ask is becareful in cold temps, they tend to jamm, and the bearings break. speaking from experience.
    Steve.
  6. Dec 5, 2018 at 9:01 AM
    #6206
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    What kind of lights do you have mounted? easy to replace the batteries? I tried checking the products discussed below, but I dont see em.
  7. Dec 5, 2018 at 9:14 AM
    #6207
    OR4x4
    OR4x4 Well-Known Member
    Portland, OR
    2018 DCLB 4x4 TRD-OR Super White
    Wow I love this build out. Great work! Are the panels waterproof? Based on the video of how to wash a GFC, that would be my biggest concern.
  8. Dec 5, 2018 at 9:54 AM
    #6208
    gman36
    San Diego, CA
    2018 Cement DCSB OR
    They are Fulterer FR 5400L, 1 52in and 1 36in. Probably similar to the ones you see on fridges, these have a load cap of 550lbs.
    I got these for now, each light takes 3 AAA. Super easy to change. They are pretty bright. Working on a LED strip solution to replace them though.
    https://www.amazon.com/SOAIY-Batter...coding=UTF8&psc=1&refRID=7ET631N8VK143R73Z0PS
    The drawer frames are coated with a bedliner so they are very waterproof. The top deck and drawers are sealed, then the top deck is cover with a marine grade carpet. Im sure I could wash it like they do, but would rather not. I've been hosing it down with the tent up and all the panels closed. Then just wiping down the interior afterwards.
    OR4x4[QUOTED] likes this.
  9. Dec 5, 2018 at 11:52 AM
    #6209
    eternus
    eternus Well-Known Member
    Longmont, CO
    2009 MGM DCSB TRD OffRoad
    I've worked my way backwards by about 30 pages but haven't found it... not sure I ever will, so I'll just re-ask.
    Insulation & sliding windows. I want to drive this thing with my dogs in the back, pulling a trailer sometimes. I have a small passthrough window, so don't need a lot but... I do need a way to go from truck cab into bed. I had messaged the folks at GFC and they said "owners were modifying their camper for a slider" but I haven't found where that is happening yet, or how... the window seems too small because of the angled sides. Anyone do this mod? Is there a different site that might be for EVERYONE, not just Tacoma owners? So far this seems like the most definitive GFC thread on the Internet, so seems like a good place to look.
    Additionally, if I ever do chilly or hot travel, I worry that the thin sheet of aluminum on the sides will do little to stave off the more extreme outside temperatures. Has anyone insulated these things? I would bet a spray on adhesive holding the rigid insulation could work to fill in faces, but would love to see these.
    Are you GFC owners out there using other forums to talk about this yet, or am I really in the best place?
    tonered and rajacat9 like this.
  10. Dec 5, 2018 at 12:01 PM
    #6210
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Ah man, if I could make a slider rear window work I'm going to be bummed to have the triangle shaped rear instead.
    Other than Instagram this is the best place I have found for modifications so far. Searching this thread can be helpful.
    tonered likes this.
  11. Dec 5, 2018 at 12:03 PM
    #6211
    eternus
    Longmont, CO
    The slider in the truck is too small to climb through, so that's not the goal. I plan to have dogs in back, the kids then in the back seat of the truck... the window would allow ventilation or passthrough, talk to the dogs, let heat/cool pass from cab back to them. It could be a flip up/down window, it could be removable, I'm just curious what others have done.
    Bed rug + velcro sounds like a win, I'll have to keep that in mind.
    I'm not a chevy guy, but plotting a Jeep Gladiator when they launch.
    tonered and butters_ like this.
  12. Dec 5, 2018 at 12:21 PM
    #6212
    Gimmeanm3
    Gimmeanm3 Well-Known Member
    David
    Denver, CO
    '18 DC LB TRDOR / 2011 BMW 1M
    I asked about the possibility of getting the larger rectangular window up at the cab end and was told no. No that this solves the slider problem, but it seems they are pretty set on that triangle window being up front.
    For my purposes I'm going to get a Mr Buddy heater for now and insulate the four wall panels with this: http://www.insulationstop.com/double-bubble-white-foil-insulation.html The borders will be 'hemmed' with gorilla tape and they will velcro into place. The dual sided is nice so you can have the reflective out (for the windows/heat reflection/privacy) and the white on the inside so it's not like a disco ball in there at night.
    butters_ and tonered like this.
  13. Dec 5, 2018 at 12:22 PM
    #6213
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The glass manufacture was seen in one of the first GFC window pics. I commented about it in a post about 4mo ago or so? They come from a company out of the PNW and do custom windows for RVs and such. Possibly ping them to see what is possible?
    Edit: Here's the post:
    https://www.tacomaworld.com/threads/hondo-garages-new-thing.516490/page-175#post-18128727
    Peninsula Glass:
    https://www.peninsulaglass.com/
    I'm shooting from the hip here. How much gap is there between the GFC and the cab window? Can a low profile slider be installed on the outside of the panel and still fit? I would guess that the stock glass could be swapped or a metal panel the same shape installed? I'm kind of guessing that a slider mod might be easiest on a non-window panel?
    Back to your original question, @ace7196 , I think it was said that if nothing fits, window cleaning is easiest by moving the GFC back a few inches.
    This is actually important to me since I have my slider open anytime that it isn't raining, even through the winter. It leaves in the perfect amount of air. I know there would be less airflow with the GFC and a front slider, but there would still be some.
  14. Dec 5, 2018 at 12:23 PM
    #6214
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    A square window really doesn’t work with the triangulated frame design. Depending on the material used by GFC for the window you could cut a hole and make a hinged plexi panel with gasketed edges.
  15. Dec 5, 2018 at 12:27 PM
    #6215
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Not that it can't be square / rectangular (smaller), just that the size chosen was the largest possible. I get why changing to square is not feasible from a parts count / vendor standpoint.
  16. Dec 5, 2018 at 12:31 PM
    #6216
    ervandew
    ervandew Well-Known Member
    it would be nice if the window could just flip down, like the one in the drifter does.
    huruta and butters_ like this.
  17. Dec 5, 2018 at 12:33 PM
    #6217
    butters_
    butters_ Well-Known Member
    Mammoth Lakes, Ca
    2000 4x4 trd manual
    Not enough
    it would be nice to have the window that has the slider and you can unlatch from inside and folds down in the bed. That style is on my current shell and makes it convenient for cleaning and access.. ive squeezed up to the front a few times to start the truck.
    tonered[QUOTED] likes this.
  18. Dec 5, 2018 at 12:37 PM
    #6218
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Agreed!
    I tried that as a friendly bet and failed. Maybe if the slider latch wasn't there and it would open to full fixed opening? If course, I'm kinda wide / round. :D
  19. Dec 5, 2018 at 12:39 PM
    #6219
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    I don't think sliding and fold down is in the cards given the limited real estate. Fold down would be nice, but I am still hoping the boot that Wiley talked about way back when still happens.
    ace7196 and tonered like this.
  20. Dec 5, 2018 at 12:51 PM
    #6220
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
