Honking When Starting Car
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1999 Taco, Jun 24, 2017.
  1. Jun 24, 2017 at 7:29 PM
    1999 Taco
    1999 Taco [OP] Member
    1999 Tacoma TRD off-raod 4x4
    none yet. Going to change
    I'm wondering if anyone knows why my car honks when i start it up. I doesn't have an alarm or key fob. It's a manual but i don't think that changes anything. (1999 Tacoma TRD Off-road 4x4)
    Thanks!
  2. Jun 24, 2017 at 7:31 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    nope no idea.
    1999 Taco[OP] likes this.
  3. Jun 24, 2017 at 7:34 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Did someone prank you and wire your horn to your starting circuit?
    doublethebass and 1999 Taco[OP] like this.
  4. Jun 25, 2017 at 2:57 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Your Truck is just happy to see you !!!
    Has this always happened or has it just started ??
    Dalandser likes this.
  5. Jun 25, 2017 at 3:02 AM
    Rackness
    Rackness Well-Known Member
    Maryland
    17' Tacoma
    Working on it.
    Don't lean on the steering wheel when starting the truck?:boink:
    1999 Taco[OP], tomwil and Dalandser like this.
  6. Jun 25, 2017 at 3:30 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Have you checked the wiring all around the engine bay - you might find some clues there - especially by the horn and driver's footwell. Other than your truck being a sentient being ala Herbie the Love Bug, it would have to be wired in a way that the horn received a signal from something other than the steering wheel control o_O
    outlawtacoma likes this.
  7. Jun 25, 2017 at 4:27 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Be pretty hard to happen from a short
    Then who can know what wiring may have been done.
    Left over alarm parts ??
    Does the Horn work like it should at other times.
    Finding your battery going dead??
    Ignition switch connected some place between the Horn relay and the horn.
    The horn switch closes the coil circuit by going to ground .
  8. Jun 25, 2017 at 4:55 AM
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
    well the horn blows, does the driver? haha had to.....
    1999 Taco[OP] and mechanicjon like this.
  9. Jun 25, 2017 at 11:25 AM
    Johhnyreb
    Johhnyreb Well-Known Member
    Jonathan
    TN
    N/A
    This.
  10. Jun 25, 2017 at 11:48 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I can think of a bunch of much better things that would be much easier
  11. Jun 25, 2017 at 12:26 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Horn is in a circuit all by itself. So you need to look for messed up wires or added on stuff.
    see attached pdf for wiring diagram.
  12. Jun 26, 2017 at 10:45 AM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    I hope you never find a solution to this problem because its outright hilarious!!!!
    BuelltonTacoma likes this.
  13. Jun 26, 2017 at 1:24 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Clock spring.
    Search "clock spring horn", I bet you'll find your solution
    Dirty Pool and 1999 Taco[OP] like this.
  14. Aug 14, 2019 at 5:54 AM
    discokryptonite
    discokryptonite Member
    ‘17 SR5
    Damn, my truck just started doing this. As I turn the if ignition there is a slight honk.
  15. Aug 14, 2019 at 8:18 AM
    DPTacomaGuy
    DPTacomaGuy Well-Known Member
    David
    2001 Tacoma 4x4
    Clock spring is probably showing its age.
    discokryptonite likes this.
