Hood scoop difference?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kolton76, Oct 1, 2024.
  1. Oct 1, 2024 at 3:05 PM
    Kolton76
    Kolton76 [OP] Well-Known Member
    Kolton
    Michigan
    2008 white Tacoma SR5
    I’m looking to put a scooped hood on my 2008 2.7L Tacoma. When I look for hoods years go from 05-11, and 12-15. What’s the difference in hoods? Wouldn’t they both fit? I’ve heard of some people talking about one has an actual functioning scoop, while one is just for cosmetic looks.
    TXpro4X4 likes this.
  2. Oct 1, 2024 at 3:07 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Neither has a functioning scoop.
  3. Oct 1, 2024 at 3:11 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I don't think there is a difference as looks, there might be a different mounts.
    Non of the Toyota scoops are functional as far as needing to pull more air into the system stock
    SR-71A likes this.
  4. Oct 1, 2024 at 3:57 PM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    As stated, neither are functional. Aesthetically the later years (12-15) the scoops are wider. Also as the 12-15s have an “updated” grille/bumper/headlights, the hoods are different. They will fit, but the lines won’t match
    SR-71A likes this.
  5. Oct 1, 2024 at 5:01 PM
    Kolton76
    Kolton
    Michigan
    Do they not work at all? Like am I able to take the molding out? Or is there no hole at all leading down to the engine bay?
  6. Oct 1, 2024 at 5:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    They are just pretty boy wanna-be fixtures. Even if you hacked it open it's not going to feed the engine.
    You do know you already have a ambient air intake in the fender, correct? It's not using underhood air.
    And yes, you need an '05-11 hood to fit / look correct.
  7. Oct 1, 2024 at 5:15 PM
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    you can take the trim/molding out. It is open, but not completely/wide open. There is some bracing for the bottom sheet metal layer in the way. Regardless, the opening doesn’t line up with the air intake, so no benefit there.
    As far as extra cooling… I’m not sure, but I doubt it. I feel like the radiator is up front getting plenty of air flow.
  8. Oct 1, 2024 at 5:26 PM
    Kolton76
    Kolton
    Michigan
    Ok I get it, they don’t technically work. Does anyone make a different molding so I can open it up? If it’s just a cosmetic thing, I might as well make it look cooler. That way when the ladies get close they don’t question how the air goes in
  9. Oct 1, 2024 at 5:27 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Drops way more panties
  10. Oct 1, 2024 at 5:47 PM
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    I’m not aware of any personally. Maybe someone does and will chime in. I guess you could always cut one yourself. The trim/molding pieces are sold separately from hood and they are available…
  11. Oct 1, 2024 at 5:51 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    That area is low pressure so with it open air will not flow into it while driving.
    That being said I removed insert and can see lots of heat escaping sitting still. The supercharger gets hot.
    Kolton76[OP] likes this.
  12. Oct 1, 2024 at 6:09 PM
    Kolton76
    Kolton
    Michigan
    A supercharger sounds badass. I would totally consider one, or even a turbo but I don’t wanna wreck my truck just yet. It’s only got 68,000 on it. Maybe one day if I ever upgrade.
    IvanhoeTaco[QUOTED] likes this.
  13. Oct 2, 2024 at 5:53 AM
    ThePositiveWay
    ThePositiveWay Well-Known Member
    SE Tennessee
    06' DCLB TRD Sport Super White
    Sony XAV-9000ES Headunit, Steering Wheel Controls, Sony ES Series Door Speakers, Alpine PWE-S8 Sub
    05-11 and 12-15 have different front ends (Gen 2 vs Gen 2.5). They did a facelift for 2012. Get the hood that matches your year range or your headlights and grill won't line up correctly
  14. Oct 2, 2024 at 7:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    The time for boost is when it's young and healthy, not old and tired
    But
    Know the up front cost (it ain't cheap)
    Know the operating cost; mpg hit, premium full, service intervals
    Know the realistic increase in HP on a 2.7. (it still won't be a rocket)
  15. Oct 2, 2024 at 7:20 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Can always go aftermarket with fiberglass or carbon fiber hoods with all kinds of scoops and louvers.
  16. Oct 2, 2024 at 7:21 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    People have opened them and tied them into the air box. IDK how much of a difference that it makes without tuning it for more air, but it's definitely possible. However from everything that I recall, the flat hood of the Tacoma leads to neutral/negative air pressure, so even having a functional hood scooped piped to the air box may not actually do anything.
    In terms of heat dissipation, again because of the mentioned negative air pressure, opening it probably wouldn't do much. Even if it did, it's rare that the Tacoma ever gets past the normal operating temp unless you're driving through Death Valley while towing a Mardi Gras Float
  17. Oct 2, 2024 at 7:51 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Did someone say...
  18. Oct 2, 2024 at 7:54 AM
    T4R_hereforbearings
    WA
    08 4Runner
    see this guy gets it, obviously why ive been forever chasing a hood scooped hood for my T4R.. just blows them right off the ladies :hearteyes::spending:
    TS4x4 and TacoTime55[QUOTED] like this.
  19. Oct 2, 2024 at 7:57 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    It's just plain sexy!
  20. Oct 2, 2024 at 8:06 AM
    T4R_hereforbearings
    WA
    08 4Runner
    Looking good!! so is that pickup parked there, just saying
    TacoTime55[QUOTED] likes this.
