Hood Scoop LED lightbar bracket by C4Fab
Discussion in 'C4 Fabrication' started by C4 Fabrication, Nov 30, 2014.
  1. Jun 6, 2018 at 12:41 PM
    #281
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The one that the OP carries - Rigid 10" SR series. I upgraded to the hyperspot version. OP had best deal I could find at the time. No complaints here.
    LePenguin427 likes this.
  2. Jul 30, 2018 at 11:30 AM
    #282
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    I just ordered my bracket, finally!
    What is the inside dimensions between the ears for the light?
  3. Jul 31, 2018 at 7:44 PM
    #283
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I was literally one of the very first to order and install this setup almost 4yrs ago and have had zero issue with water intrusion and don't see it any different than the grill opening. I suppose road grim and cleaning will have a bit to do with where you live and winters there, but I've never removed mine to clean it and it still looks fairly clean back in there and works excellent. I've got around 40k miles with this bar installed and would still highly recommend this setup and Caleb's / C4Fab bracket. And removel to clean already isn't a big deal if needed.
    Spot/Hyper Spot
    dborrer likes this.
  4. Feb 5, 2020 at 11:21 AM
    #284
    bloggerstomper
    bloggerstomper Well-Known Member
    CA
    Crumpy
    Damn, this looks so cool. I am definitely going to get one. Does anyone know if there's going to be a group buy or any coupons available for TW users?
    It's not a big deal if not, this is going on my truck no matter what!
  5. Aug 23, 2020 at 5:22 PM
    #285
    Dang Quesadila
    Dang Quesadila Well-Known Member
    SW Florida
    2011 TRD Sport DCLB 4WD
    Dobinsons/ MLO GTS Suspension, FJ 17" wheels, RIGID LED fogs, X2Power AGM battery, Extended stainless/braided brake lines, OBA.
    What beam pattern are most running with this?
    I'm thinking about going with the combo pattern, but not sure if being set so deep into the scoop if it will negate the wider beams of the combo ‍♂️
  6. Aug 24, 2020 at 12:56 AM
    #286
    Chuy
    Lakeside, CA
    Silver Taco
    The vendor can tell you which light he sells the most. I got the hyperspot. When I shopped around, vendor had best pricing. Sucker is bright, even with the mesh cover in place.
    Dang Quesadila likes this.
  7. Sep 23, 2020 at 4:28 PM
    #287
    Ribbit777
    Ribbit777 New Member
    Robert
    2008 Tacoma trd sport 4wd
    I went onto your website but I didn't see the kit you mentioned in your first post. Do you still sell it as a kit or does it need to be purchased separately?
  8. Dec 7, 2020 at 10:11 PM
    #288
    JBlaze
    JBlaze Member
    Indian Trail, NC
    2005 Tacoma Pre Runner Access cab V6 4.0 MT
    Eibach Stage 1 lift kit (shocks, struts, and springs) OME upper control arms ICON add a leaf kit Moog tie rod ends and sway bar links Fuel Anza Anthracite 17×8.5 -6 wheels Falken 275-70-17 tires MBRP catback exhaust Spectre Cold Air Intake Powerstop Rotors and Pads ARB Single Compressor w/Expedetion Essentials bedside compartment mount AlphaRex Pro series headlights and taillights Diode Dynamics SS3 fog lights Westin Bull Bar Magnum Raptor style steps TacoVinyl color match custom grille Tyger Pocket Style Fender Flares AVS in channel window vents Prinsu Roof Rack RedLine Tuning hood struts Husky toolbox Fia Leatherlite seatcovers Husky weatherproof floormats front Weathertech Floormat rear JVC dvd/bluetooth player Rockford Fosgate 6×9s, 6×5s, 1" tweeters and 8" powered sub Sparco carbon fiber gas pedal OMP clutch and brake pedal Meso Customs map and dome lights AJT Designs climate control knobs and matching keyfob TRD FJ cruiser shift knob CH4×4 switches for compressor, fog, and grille lights BD Diesel throttle controller
    Super interested in this mod for my 2005 Taco...Ive been to your site, and was looking at the lighting options and see there is an amber option...but there is no way to select it...how do you go about specifying thats what you want to order? Also which is the more intrusive to say a head on driver, the spot or flood...or both and needs to be treated as high beams?
  9. Dec 7, 2020 at 11:46 PM
    #289
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    None of them would be street legal so you must treat all of them like high beams.
    El Tano and JBlaze[QUOTED] like this.
  10. May 18, 2021 at 10:24 AM
    #290
    bloggerstomper
    CA
    Crumpy
    Does anyone else have any issues with the fitment?
    Mine is jammed in there and there is no room for adjustments.
  11. Jan 5, 2024 at 6:18 PM
    #291
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    I thought this was no longer available .... If anyone wanted to sell a used bracket set up.... i'd be interested.
  12. Feb 15, 2024 at 9:56 AM
    #292
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    wait, high beams are not legal??? it seems to be the only one they use now days :smack: ......
  13. Feb 15, 2024 at 9:15 PM
    #293
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    That is so true.
    Unfortunately
