Hood Scoop LED lightbar bracket by C4Fab
Discussion in 'C4 Fabrication' started by C4 Fabrication, Nov 30, 2014.
  1. Dec 3, 2014 at 8:52 PM
    Atomic47
    Atomic47 Well-Known Member
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    Leveling kit, AAL, air-ride, Rear diff breather mod, Illuminated 4wd Switch, 4 more D rings, fog lights anytime, 7 pin relocate, Coca-Cola mod, TRD Off-Road hook, Weathertechs, secret custom cargo light, 09 lower dash panel, heated seats, 2013 oem touch screen radio, reverse camera added into Pop'n'Lock locking tailgate handle, black powder-coated TRD Sport rims, 32" light bar in custom fabricated mount, aux reverse lights in rear bumper
    I really like that the mesh is intact. It makes the light less obvious and protects it at the same time.
  2. Dec 4, 2014 at 7:52 AM
    C4 Fabrication
    C4 Fabrication [OP] Well-Known Member Vendor
    Caleb
    South Dakota
    07 DCLB Sport
    2" lift, 285/70/17 BFG TA KO2's, baja bumper, bedrack with swing out, CVT RTT, Leather interior, heated seats, JBL, remote start, K&N intake, Hood Scoop LED lightbar mod.
    Yeah I like that too, it also makes it very hard to notice the light in there. its a very subtle mod.
    ColtsTRD likes this.
  3. Dec 4, 2014 at 6:35 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Western Washington
    BSP 4x4 TRD Sport DCSB
    Not enough
    How close to the mesh does the light sit?
  4. Dec 4, 2014 at 7:29 PM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    about an 1 1/2" away
  5. Dec 4, 2014 at 7:30 PM
    ndcmack
    NICK
    Western Washington
    Not enough
    Thanks. Last question,
    Any hood glare back at the driver?
  6. Dec 4, 2014 at 7:51 PM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    none at all
  7. Dec 4, 2014 at 9:43 PM
    ndcmack
    NICK
    Western Washington
    Not enough
    PM'd
  8. Dec 5, 2014 at 4:08 AM
    willee51
    willee51 Well-Known Member
    Bill
    Forest, VA
    2015 TRD-Sport 6-cyl DCLB MGM
    Weathertech window vents, bed mat, Nerf Bars, Husky mats, sPOD, Marathon seat covers, Michelin LTX AT2's
    ..............hoping to get a 2015 w/in the next few months:D
    Any plans to have this set fit models past "11"?
  9. Dec 5, 2014 at 5:28 AM
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    Looks like a well-built product!
  10. Dec 5, 2014 at 7:25 AM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    I would like to design a kit for 11+, but I have not been able to get access to an 11+ truck with a scoop yet. I do know that the scoop on the 11+ models is not nearly as tall. I have a feeling there will not be a light narrow enough to fit. The Rigid 10" SR light that I use with my kits is a very tight fit in the 05-11 models.
  11. Dec 5, 2014 at 4:00 PM
    willee51
    Bill
    Forest, VA
    :ohsnap::angrygirl:
  12. Dec 5, 2014 at 9:45 PM
    ndcmack
    NICK
    Western Washington
    Not enough
    Any night shots?
  13. Dec 6, 2014 at 9:33 AM
    NPulver
    NPulver Active Member
    Black Hills
    10' DC Tacoma TRD
    ProComp 3 inch Lift, 255/85/16
    Love the design, too bad i dont have a scoop!
  14. Dec 7, 2014 at 1:23 AM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    I will get some night shots for you guys!
  15. Dec 7, 2014 at 1:23 AM
    #35
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Thanks!
  16. Dec 8, 2014 at 9:31 AM
    #36
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Here are some night shots as requested. This is with a spot/flood combo light. If I were to do this again, I would recommend a spot light beam. As you can see in the first pic, the hood blocks some of the up close light coverage, so I believe that a flood pattern isn't as beneficial as a spot would be in this location.
    First one is the LED Bar only
    this is my low beam headlights only. I do have IPF 65 watt bulbs in my headlights, so keep in mind that they are much brighter and cover more distance than the factory bulbs.
    This is with low beams (again IPF 65 watt bulbs) and the LED bar both on. you can see that the LED bar is a much brighter "white" colored light and it also extends out past the low beams a bit farther.
    The thing I really like about the scoop mounted bar is that it puts some of the light up higher than the headlights. That combined with a spot pattern light allows you to see objects that are past the headlight coverage area more easily.
    Wyoboypt likes this.
  17. Dec 8, 2014 at 5:43 PM
    #37
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    Looks good where did you get the iPad bulbs? And which color temp are they I need some brighter headlights and yours look bright, what been looking for...
  18. Dec 8, 2014 at 5:56 PM
    #38
    ndcmack
    NICK
    Western Washington
    Not enough
    Looks great! Agreed that spot is better in this location based on hood cutoff. PM coming
  19. Dec 8, 2014 at 9:28 PM
    #39
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    The bulbs I have are IPF 65 watt H4 replacement bulbs. The bulbs are actually from an old headlight conversion kit I had on my 87 4runner. I thought they were 65 watt, but this link says they are 55-90 watt. Im not sure exactly how that is figured. These should be the same bulbs I have.
    http://www.4wheelparts.com/Lighting...lbs.aspx?t_c=14&t_s=67&t_pt=6065&t_pn=ARBX72S
  20. Dec 8, 2014 at 9:29 PM
    #40
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Thanks! got your PM
