Hood Scoop LED lightbar bracket by C4Fab
Discussion in 'C4 Fabrication' started by C4 Fabrication, Nov 30, 2014.
  1. Jan 19, 2015 at 1:26 PM
    #121
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    not sure if i missed it, but is there another light besides a Ridgid that has been confirmed to fit? Cheaper option would be nice :)
  2. Jan 19, 2015 at 1:32 PM
    #122
    C4 Fabrication
    C4 Fabrication [OP] Well-Known Member Vendor
    Caleb
    South Dakota
    07 DCLB Sport
    2" lift, 285/70/17 BFG TA KO2's, baja bumper, bedrack with swing out, CVT RTT, Leather interior, heated seats, JBL, remote start, K&N intake, Hood Scoop LED lightbar mod.
    At this point in time there are no other lights that will fit this application. Rigid is the only company that offers a 10" that is slim enough to fit.
  3. Jan 19, 2015 at 5:14 PM
    #123
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    :woot:Keep us posted :D
  4. Jan 19, 2015 at 5:24 PM
    #124
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
  5. Jan 19, 2015 at 5:26 PM
    #125
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
  6. Jan 24, 2015 at 11:32 AM
    #126
    NBBAZ
    NBBAZ Well-Known Member
    Arizona
    2010 Toyota Tacoma DCSB Sport 4x4
    C4,
    I'm thinking seriously about pulling the trigger on buying this!
    I do a lot of night driving and have to constantly be on the lookout for deer, elk, and other critters crossing my path.
    :confused:
    What light option do you think would be best for this? Seeing critters both on and off the side of the road?
    Do you notice the light bouncing around while driving down the road?
    These lights are very expensive too me!:eek:I never understood why they're so much. Are they really that much better than the old school KC or Hella style lights?
    I don't have a problem paying for good stuff as long as it's not an over inflated price. I know you don't set the crazy price for these, the manufacturers do, but damn! $200 - almost $400 for a 10" light!:eek:
  7. Jan 24, 2015 at 5:50 PM
    #127
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    I do realize that the rigid lights are expensive, but YES they are way better than the old school halogen beam Hella's. I have three of the 55 watt 6" round hellas on the front of my 4runner and the rigid 10" single row far outperforms them in distance, coverage, and brightness. If you are looking for more of a full coverage type beam pattern, then I would suggest the driving beam style of the rigid 10" single row. check out the pics that DJSPEC posted on the last page, he used the driving pattern light and its amazing how much coverage and distance it can accommodate. The driving beam is more expensive than the standard flood or spot beam, but its worth it.
    If you want even more coverage in the ditches than what the driving beam setup in the scoop can offer, than I would suggest adding some higher quality flood beam LED lights to your front bumper which you can aim more into the ditches.
    If you decide to go with the driving beam, I can sell you that light for 275.00, which is a pretty low price compared to most places you will find it.
    As far as the light bouncing, that does not happen at all. I have designed my bracket to fit well and keep the light firm in position inside the scoop. If you were to ever notice any movement of the light, it would be from your entire hood vibrating up and down while off-road.
  8. Jan 24, 2015 at 8:38 PM
    #128
    NBBAZ
    Arizona
    Is that 275 wiwith the bracket or just the light?
  9. Jan 24, 2015 at 8:45 PM
    #129
    NBBAZ
    Arizona
    Oh, plus 65 for the bracket, right?
  10. Jan 24, 2015 at 9:28 PM
    #130
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    yes the driving beam version of the Rigid single row 10" is 275 by itself. Then another 65 for the bracket kit.
  11. Jan 25, 2015 at 7:00 AM
    #131
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Great explanation!!!
  12. Jan 28, 2015 at 2:49 PM
    #132
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    I spent some time re-thinking the original design of this bracket trying to figure out how to use less hardware and make it one piece without any welding reguired. Here are some pics of the new brackets. They are now laser cut 14ga press brake formed steel brackets that will be powdercoated black. price is still 75.00 for the bracket. They are now even easier to install!!
    The remaining old style powdercoated brackets that I still have are now on sale for 55.00 each! PM me to make your order before they are all gone!
  13. Jan 29, 2015 at 5:50 AM
    #133
    NBBAZ
    Arizona
    It's awesome that you're continuously improving on your idea! Just because something work good doesn't mean it can't be improved. Nice job!
  14. Jan 29, 2015 at 6:30 AM
    #134
    Yan.trdPR
    Yan.trdPR New Member
    Yan
    Puerto Rico
    TRD 4x4 2013
    Remove emblems dips rims
    PM Sent!!!
  15. Jan 29, 2015 at 7:44 AM
    #135
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Thank you!
  16. Jan 29, 2015 at 7:44 AM
    #136
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Got it!
  17. Jan 29, 2015 at 7:51 AM
    #137
    ThomasMore66
    Dallas/Fort Worth & Durango
    Why can't the TRD OR have a scoop? I'm missing out on all the fun. I want a scoop. Cool kids all have scoops...
  18. Jan 29, 2015 at 7:52 AM
    #138
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Haha, I agree! I think the TRD's should have came with a scoop also. Have to special order a TRD with a sport scoop from the factory I guess, if that's even possible.
  19. Feb 4, 2015 at 9:47 PM
    #139
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Bump for OP! Finally got my bracket and light bar installed:D. Top notch fit and finish. I would highly recommend C4 fab and Caleb for this product, His communication and product are excellent! Pictures to follow soon...
  20. Feb 5, 2015 at 6:38 AM
    #140
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Thanks dude! I forgot you hadn't even installed yours yet its been so long since you ordered!
