Hood Scoop LED ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rollingstoned, Nov 25, 2018.
  1. Nov 25, 2018 at 3:36 PM
    Rollingstoned
    Rollingstoned [OP] Well-Known Member
  2. Nov 25, 2018 at 7:51 PM
    HillJackJDS
    HillJackJDS Well-Known Member
    Dale
    2008 Tacoma 4WD
    It wouldn't be hard to wire, just remember to check your local laws as most states will not allow on road use of these lights above the level of the headlights.
    BassAckwards likes this.
  3. Nov 25, 2018 at 8:29 PM
    Rockdwg
    Rockdwg Well-Known Member
    Rapid City, South Dakota
    2008 Tacoma DCSB trd off road
    Look up C4 fabrication he does great work. He can sell you a bracket or a bracket an light combo with full instructions on the install.
  4. Nov 25, 2018 at 10:32 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I seem to remember someone doing it and glare bounced off the hood making it a loss?
    jboudreaux1965 likes this.
  5. Nov 25, 2018 at 11:01 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Thought about doing the same thing on mine, but remembered when I tried to put night vision IR's and Cam in there, result was basically like you described. Hood reflection flared out scoop Cam and cams in the cab. So most likely light bar would basically do the same, the hood would limit your light output and probably reflect some back on you. If you try it, please post, interested to know if it would work, if it does, I'll do it :)
