Hood Vibrating
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mjones1970, Nov 20, 2015.
  1. Nov 21, 2015 at 10:22 PM
    #41
    mxwrench
    mxwrench Well-Known Member
    Brian
    Hi Desert, So Cal
    2016 DCSB TRDOR 4X4 JBL SW
    The repair trick will be to get the old glue patched cleaned off and the surface prepped without damaging or denting the hood panel and lower support structure, as I believe the support structure is spot welded in place and is non removable. For any bond to work and last, the surface preparation is key.
    In my opinion, the glue joints themselves failed and not the initial surface prep, so I would put the blame on the adhesive manufacturer and not Toyota directly. Regardless, I am going to push for a replacement hood assy. Perhaps one with the scoop, as I think we finally found something that the scoop is good for (reinforcing the hood panel)!
  2. Nov 23, 2015 at 6:12 AM
    #42
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Case filed...
    0uTkAsT likes this.
  3. Nov 23, 2015 at 7:59 AM
    #43
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    same here.
  4. Nov 23, 2015 at 8:07 AM
    #44
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    Mine does this too. Will check the glue tonight.
  5. Nov 23, 2015 at 9:00 AM
    #45
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Seems like something that should have been caught before it hit the showroom.
    specter208[QUOTED] likes this.
  6. Nov 23, 2015 at 9:38 AM
    #46
    FritoBandito
    Texas
    Confirmed. Mine has come unglued. Limited made in Mexico. Do you all think it's best to call Toyota or take into the dealer now or wait for them to issue a TSB?
  7. Nov 23, 2015 at 9:41 AM
    #47
    Shelf Life
    Rob
    Central Oregon
    Probably the more folks that call, the better to light a fire for the TSB.
    73LandCruiser and specter208 like this.
  8. Nov 23, 2015 at 10:18 AM
    #48
    swimmer
    Tucson
    2016 TRDORAC4WD
    This. Call Toyota, then call your dealer.
  9. Nov 23, 2015 at 10:26 AM
    #49
    FritoBandito
    Texas
    Done. Case opened with Toyota. Calling dealer now.
  10. Nov 23, 2015 at 11:02 AM
    #50
    Jaybird67
    Jaybird67 Member
    Louisiana
    case filed
  11. Nov 23, 2015 at 11:16 AM
    #51
    FritoBandito
    Texas
    1 (800) 331-4331
    Suxdsmdmr and 0uTkAsT like this.
  12. Nov 23, 2015 at 11:19 AM
    #52
    swimmer
    Tucson
    2016 TRDORAC4WD
    In fairness, this is exactly what the customer support person told me was the best way to get the problem addressed. Called the dealership and will drop the truck off Monday.
  13. Nov 23, 2015 at 11:26 AM
    #53
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Oh man something else now :facepalm:
    I still need to get my front lights replaced due to them burning and amber lens (running lights).
  14. Nov 23, 2015 at 11:39 AM
    #54
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    No issues on my sport hood but it's only got 500 miles
  15. Nov 23, 2015 at 11:51 AM
    #55
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    a little gorilla glue and five minutes applying it without any prep work would solve the problem before you can get halfway to the dealer.
    I know it sucks being a brand new truck and all, but it's really a simple little thing to resolve. If you have to, I would wait for the next oil change and shame the dealer into doing it for free while they fix the hood problem to cover your time.;)
  16. Nov 23, 2015 at 11:54 AM
    #56
    swimmer
    Tucson
    2016 TRDORAC4WD
    Don't disagree that a DIY fix is possible but, I'd like Toyota to know this is an issue and them paying to fix it is the best way.
    wachuko likes this.
  17. Nov 23, 2015 at 12:22 PM
    #57
    swimmer
    Tucson
    2016 TRDORAC4WD
    I am think you'd want some adhesive effect beyond expanding foam. A couple of long beads of gorilla glue near the broken joints would be my first shot if I were attempting a fix.
  18. Nov 23, 2015 at 12:39 PM
    #58
    FritoBandito
    Texas
    I'm taking mine into the dealer Wesnesday morning. I also agree that this is an easy DIY fix but would rather let them do the right thing.
    0uTkAsT likes this.
  19. Nov 23, 2015 at 1:56 PM
    #59
    InLuvWithMyTaco
    InLuvWithMyTaco Well-Known Member
    Milliken, CO
    2016 Inferno TRD OR
    Just checked mine, Mexico made Inferno, and it too has about 8 or so blotches of adhesive either coming apart or detached completely. I'm with Outkast, I'll be filing a claim, but will probably be using expanding foam to adhere it back together. Stuff works very well for that.
  20. Nov 23, 2015 at 1:57 PM
    #60
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Well I'll be damned. Read this thread, went out to check under the hood and sure enough the middle support skin structure is coming unglued. Filing with Toyota and making an appt. with service tomorrow.
