Hood Vibrating
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mjones1970, Nov 20, 2015.
  1. Nov 23, 2015 at 1:59 PM
    #61
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    I would just let the dealer handle it. Just your luck that the dealer will say that the expanding foam increased the gap and broke the adhesive, and deny your claim.
  2. Nov 23, 2015 at 2:15 PM
    #62
    mjones1970
    mjones1970 [OP] Well-Known Member
    It's probably best that the dealer deal with this. My luck if I did a DYI and later had some separate issue they'd claim warranty voided. Plus, I forget who said it but earlier in the thread someone mentioned that a DYI fix like expanding foam may cause hood ripples or an uneven surface on the hood.
    I know when I take mine in I'll point out to the dealership to ensure all the metal is the way it's supposed to be. But, that I want my hood to stop vibrating as it's very annoying. It's like the big Gary mole on the face, I can't stop looking at it
  3. Nov 23, 2015 at 3:06 PM
    #63
    InLuvWithMyTaco
    InLuvWithMyTaco Well-Known Member
    Milliken, CO
    2016 Inferno TRD OR
    Very true on the notion that they might use that as cause for a warranty void. I'll probably leave it be until my 5k service which is in about a month.
  4. Nov 23, 2015 at 3:28 PM
    #64
    Scoops
    Scoops Member
    Crestview, FL
    2004 Jeep GC
    Sub'd
  5. Nov 23, 2015 at 3:49 PM
    #65
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Oh boy have to watch
  6. Nov 23, 2015 at 4:14 PM
    #66
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
  7. Nov 23, 2015 at 4:49 PM
    #67
    TacoSeattle
    TacoSeattle Well-Known Member
    2016 Tacoma TRD OR 4x4 v6 SB Quicksand
    Here is what my dealer said when I told her about this potential issue on hood structure adhesive separation and that mine will be delivered by 12/12/16. No problem as it is a warranty issue and will be covered. We will inspect it upon arrival and for the first 3 years. If it is widespread Toyota will give dealers the recommended fix and potentially a recall which does not have to be Safety NTSB forced. I suggest if you have a problem go see your dealer first and get it logged in with them.
    Suxdsmdmr likes this.
  8. Nov 23, 2015 at 5:05 PM
    #68
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    Same.
    Mine is a Texas made...09/15 date
    I have not had any vibrating or flexing issues yet, but there are some spots coming apart for sure...I had planned on lettting the dealer do my first oil change, so I'll file it then as well...
  9. Nov 23, 2015 at 5:28 PM
    #69
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    if you really wanted to try and fix this problem yourself i'd steer clear of anything that cannot flex and expand in different temperatures. i don't think gorilla glue or expanding foam are able to do that.
    you'd want to use auto seam sealer, something like Fusor 800 Seam Sealer or 3M seam sealers (some are available in different colors)
    chances are this is how the dealers are going to be instructed to resolve the problem.
    FritoBandito likes this.
  10. Nov 23, 2015 at 5:52 PM
    #70
    FritoBandito
    Texas
    Good point. I may try something from 3M. For things such as this I will usually do a better job than the dealership. I know how to apply glue for eff sake. LOL.
    3M 08115 Panel Bonding Adhesive - 200 ml https://www.amazon.com/dp/B000PEW4MI/ref=cm_sw_r_cp_awd_xh8uwbVSHJQZ1
  11. Nov 23, 2015 at 8:20 PM
    #71
    ToyFXR88
    ToyFXR88 Well-Known Member
    WI
    2016 MGM DCSB TRD Sport 6MT
    This guy is spot on. Don't attempt any DIY repairs and then expect Toyota to cover it later on. My service manager would not approve warranty work on stuff customers attempted to fix themselves for fear Toyota would deny the warranty claim, causing our dealership to not get paid.
    With that being said, my sport is not experiencing this issue. I will check my adhesive tomorrow, but I bet it's due to the scoop adding rigidity like others said.
  12. Nov 24, 2015 at 8:17 AM
    #72
    tacojason
    tacojason Active Member
    Austin, TX
    '16 4Runner TEP w/ KDSS
    I just checked mine (Texas built 10/15)...every single blob of goop has separated. I called Toyota Corp. and my guy at the dealership. Taking it in on Monday for an inspection. I'm sure it will be a super easy fix...once they figure out what to do.
  13. Nov 24, 2015 at 10:29 AM
    #73
    desracerx
    desracerx 16 Inferno
    Las Vegas
    2016 Inferno Tacoma DCOR 4x4
    Just got back from the dealer and they were basically clueless as to how to fix the broken adhesive. They were going to send the truck to a body shop (i.e.) service king. I have had nothing but a headache with the quality of their work so I refused to send it there. I spoke with the manager and he said he would use a different body shop but couldn't guarantee the work?????? 40k to Toyota and this is how they respond to an issue? This is my 4th Tacoma and not one issue with any of the previous 3! Pissed doesn't begin to explain my feeling! I guess I will try a different dealer next week?
    unclemat and mjones1970[OP] like this.
  14. Nov 24, 2015 at 10:42 AM
    #74
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    They should have contacted Toyota tech support to see what they recommend. Do you know if they did that?
    scottalot likes this.
  15. Nov 24, 2015 at 10:58 AM
    #75
    desracerx
    Las Vegas
    I contacted Toyota first. They took the information, vin, etc. and directed me to the service department at the local dealership. They had the techs as well as the service manager look at the situation and after a 2 1/2 hour wait they concluded a body shop was the fix? What made me laugh was I mentioned how Toyota gluing your hood together seemed a little CHEAP, and they threw other auto makers under the bus saying they glue fenders on their vehicles.
  16. Nov 24, 2015 at 11:10 AM
    #76
    tombiosis
    T
    Ottawa Canada
    following this thread with great interest.
    I don't think this is really a big deal though. I know the trucks are expensive, but this seems to be an easy fix to me. I would wait awhile, and I'm sure once more owners file Toyota will have a proper remedy. I would like them to send some of the adhesive they used at the factory to their dealerships, where their techs can apply some more, from a better batch. The blobs of goop that are still holding on mine are holding well, and it looks like a good flexible product. Someone mentioned upthread that maybe it was a bad batch or two. Maybe they just need to tweak the formula?
    Either way, its not worth freaking out over...
    mjones1970[OP] likes this.
  17. Nov 24, 2015 at 11:19 AM
    #77
    tombiosis
    T
    Ottawa Canada
    never really thought about the paint...but I guess you're right. Mine doesn't "jiggle" or vibrate so far...that would drive me batty for sure.
    0uTkAsT likes this.
  18. Nov 24, 2015 at 11:21 AM
    #78
    swimmer
    Tucson
    2016 TRDORAC4WD
    I don't think anyone is panicking, we just want the hood assembly to be the way it was intended/engineered.
  19. Nov 24, 2015 at 11:31 AM
    #79
    TOMRR
    TOMRR Well-Known Member
    Tom
    Mass
    2016 TRD OFFROAD, DCSB, AUTO, BLAZING BLUE, PREMIUM JBL TECT.
    Stock TRD OFF ROAD DCSB AUTO JBL TECT. Bed Mat Heated and turn signal mirrors Wet Okole Front Seat Covers Prodigy Brake Controler Front Skid Plate Power Wagon Badge Tint Driver and Pessenger door windows Inchannel window vents
    I stop by my dealer and told my sales person about the issue and he was very glad to hear about the vibrating hood issue but so far they had no one come back to them about it. so they had two 2016 on the lot 1=DC OFF ROAD and a DC SPORT so I took him up to them we pop the hood and bingo you could not help but see the issue. He told me both truck were sold and he would get them into the shop and make them right.
    My build date is DEC 4TH and My sales man assured me it would be checked out before I take owner ship
    mjones1970[OP] and 0uTkAsT like this.
  20. Nov 24, 2015 at 11:43 AM
    #80
    tacojason
    Austin, TX
    I had the same experience...I was given a ref #. I asked the customer service rep if I was supposed to write it on a few pieces of paper, fold said pieces of paper, and use them as shims. She was nice, but clueless. It's not a big deal. I'm heading in on Monday.
    TOMRR likes this.
