Hood Vibrating
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mjones1970, Nov 20, 2015.
  1. Aug 8, 2018 at 7:57 AM
    #981
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    But, the flexing is what's pulling the hoods apart. It seems something like jb weld would keep it together. People even use it to seal cracked engine blocks, the stuff really is like a weld.
  2. Aug 8, 2018 at 8:41 AM
    #982
    sierra141
    sierra141 Mean Green
    New Mexico
    18 TRD Offroad
    Kings
    I thought about using liquid nails as well, but I think the glue they used at the factory flexes like some kind of putty. Its kind a squishy if you press on it, especially after driving your truck (with engine heat)
    So far mine is way better and we have been in the triple digits here in Texas south west desert. If you try JB weld keep us posted how it turns out for you.
  3. Aug 8, 2018 at 8:43 AM
    #983
    Grossomotto
    2017 4WDV6LB6MT
    I’m fine looks like all is good but only have 5100 miles. If it starts seperating I’ll perhaps try it.
    sierra141[QUOTED] likes this.
  4. Aug 8, 2018 at 3:26 PM
    #984
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    The hood skin is not pulling apart. Its the lack of support points making contact with the hood skin. The putty from the factory remains soft for a reason. You want it to flex with movements of the truck as well as temperature of the metal. No flex means it will create dimples in the hood. The defect is the number of contact points or lack there of. This causes the factory advise to lose contact with the metal. Adding product like 3M NVH to all areas of the hood support increases the contact to reduce vibration and remains flexible to adapt to temps and wind moment.
  5. Aug 8, 2018 at 4:16 PM
    #985
    nartmot
    nartmot Well-Known Member
    Is it possible to use too much of the NVH? I was going to use the whole bottle and apply it anywhere there is a gap.
  6. Aug 8, 2018 at 9:59 PM
    #986
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    The only thing I'd worry about is semi-trapped spaces since the engine bay gets some spray in wet weather. Maybe a dashed spacing would be better, dunno, just my .02. Certainly anything more than the few stock blobs would improve the bond proportionately.
    nartmot[QUOTED] likes this.
  7. Aug 9, 2018 at 5:32 AM
    #987
    EdgeCrusher
    Chicagoland
    Naw I used the whole thing.
  8. Aug 9, 2018 at 5:52 AM
    #988
    Broheim
    Broheim Well-Known Member
    San Antonio, TX
    2023 TRD Pro
    Its glue. Under extreme heat from sun and engine heat. Why glue is being used in the first place is the problem.
    If we are concerned about cost and glue failing on an expensive item...
    A couple of my $350 nike soccer cleats have had their bottom "cleat" unglued and peel right off the upper several times on different models of shoes just from using them as intended.
    I just Gorilla glue them back on and they're good to go.
    Again..its just glue.
    These are $30k trucks..or less. Markup doesn't count. It's the same hood from SR to Pro.
    It's not a land rover or amg man. It's still a Japanese truck.
    Cost of the truck doesn't mean anything if they're using glue to manufacture parts.
    You want an all in one piece frame and hood?.. then look at a more high end vehicle.
    Let's get past the 'expensive' 30k tacoma thing already. This is 2018.
  9. Aug 12, 2018 at 7:33 PM
    #989
    Andypii
    Andypii New Member
    Ventura Ca.
    2018 SR5 DCSB 3.5
    UPDATE: Got my sr5 back, and I must say they did a good job. Paint matches perfectly, all EO emissions labels, and other sticker in place. Im a master autotech and often do used vehicle inspections for my customers and this one would even fool me. :amen: If it ever happens again- im just going to Lowes for a tube of goop lol
  10. Nov 8, 2018 at 12:34 PM
    #990
    Hijynx
    Hijynx Well-Known Member
    Pacific Northwet
    2019 Offroad DCLB
    2019 offroad still with the same adhesive separation problem. baja built 09/18
  11. Nov 8, 2018 at 12:37 PM
    #991
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    That's frustrating. Dealership sourced my fix through a local body shop. Much better. Crazy they haven't addressed this 4 years in.
  12. Nov 22, 2018 at 6:25 PM
    #992
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    I just picked up my used 2016 and fell outta warranty a week ago. Corp won't even consider covering it which is really disappointing given this issue is wider spread then just a batch or two. I just bought some 3M NVH to do the fix myself next week....at least I know it's done well with the right material just like my oil changes :thumbsup:
    Thanks for all the comments on this thread!
  13. Nov 22, 2018 at 8:40 PM
    #993
    woodshampoo
    woodshampoo Well-Known Member
    VA
    2018 DC OR 4x4
    Dealer ordered a new hood for my OR 18. Was trying to get a sport out of the deal.
  14. Dec 9, 2018 at 11:19 PM
    #994
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    19 OR DCSB Premium Tech, same problem. Bought an "Amazing Goop" at my local O'rilley Auto store, everything is solid now. I can't believe they haven't remedied that in over 3 years!
  15. Dec 10, 2018 at 5:09 AM
    #995
    wahoobie
    chris
    Suffolk, VA
    Just a follow up that the diy fix went well and all that extra hood waffle is gone. I made sure to take the hood off and flip it over on some padding to support the outer edges. That way I didn't put in any dimples from pushing down any section in the middle. After several highway runs since then it is all holding great. Even if I had to do this again in the future it was a quick and effective fix. If anyone is local to 23433 and wants to borrow the application gun just PM me...happy to share since it's $30+ for a possible one-time use.
  16. Dec 10, 2018 at 2:21 PM
    #996
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    I have the gun and the NVH. Did you just put the NVH on the tabs where the factory stuff was or did you lay a bead along the length of those trusses? Just curious how much the stuff expands. Any pics?
  17. Dec 10, 2018 at 2:26 PM
    #997
    wahoobie
    chris
    Suffolk, VA
    For me I saw no expansion, acted like caulk. I did just reapply around the original points that broke away but I really tried to get into those sections well.
  18. Dec 10, 2018 at 3:33 PM
    #998
    WOTaco
    Good to know. Thanks
  19. Jan 3, 2019 at 1:41 PM
    #999
    Gothy666
    Gothy666 Well-Known Member
    2019 TRD Off-Road
    New to the forum here. I picked up my 2019 Off Road on Saturday and noticed it had that vibration as well. Didn't think too much of it but researched on the forums and apparently it's a common problem. Taking it to the dealership on Sat morning, wish me luck gentlemen.
    BlueShadow, Lpbrown999 and Inferno! like this.
  20. Jan 30, 2019 at 2:48 PM
    #1000
    Gothy666
    2019 TRD Off-Road
    So this was the Toyota body shop's "fix." Not to mention, it didn't even get rid of the problem as I still have fluttering at highway speeds. Spoke with the shop manager and he said he contacted Toyota corporate and that there is no TSB to fix it, which I already knew. He did at least admit that per his research, it seemed to be a fairly common problem. So here is my dilemma; he said he can caulk all around it, take decals off, and respray the underside of the hood to make it look "close" to factory, or, we can wait on Toyota to replace the hood. I'd prefer option 2 (replace hood), but I'm afraid that it will have the same damn problem. I want a Sport hood given that they have more structural integrity. What should I do, any advice?
