Hooking up bed lights to door switch
Discussion in 'Lighting' started by stump jumper, Apr 12, 2013.
  1. Apr 12, 2013 at 6:05 AM
    stump jumper
    stump jumper [OP] Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I am sure some where in this forum I could find a thread on it. Has anyone hooked their bed lights up to the door switch so they come on when the door is opened? I can easily go to the battery but prefer that the switch is not always hot.
  2. Apr 12, 2013 at 6:11 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You might have a tough time making that work properly. The dome lights in the truck are actually controlled by the ECU, it's not just a simple door switch contact. The light fades out when it turns off also, not just a clean cut off. I wouldn't add more lights to that circuit, which leaves you with using that circuit as a trigger for a relay. The fading out could cause the relay to act up as the power slowly fades away.
  3. Apr 13, 2013 at 4:39 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
  4. Apr 14, 2013 at 4:06 AM
    stump jumper
    Bill
    Texas
    The rope LEDs do not pull many amps. That and the fact that my Fords with a cargo light were hooked up that way. I am going to go ahead and try it.
  5. Apr 14, 2013 at 7:23 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    This thread. Please remember that the blue wire is a fading ground.
    http://www.tacomaworld.com/forum/lighting/267483-led-lights-under-truck.html
    Also, if you change all your interior lighting to LEDs, then your amp draw, even with the LED bed lights should still be lower than stock.
    My white 5 meter LED strip light pulls 2 amps.
