hooking up my pioneer avh4200dvd need a little help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AustingAnderson20, Aug 24, 2011.
  1. Aug 24, 2011 at 5:58 PM
    AustingAnderson20
    AustingAnderson20 [OP] Member
    Austin
    North Wilkesboro, NC
    2005 Toyota tacoma access cab l
    grillcraft grill, K&N cold air intake, Prosport gauges, 3in toytec suspension lift, xd wheels, bf goodrich 285,75,r17,betterbuilt lowpro toolbox
    i need some help to make sure i ordered all i need to hook up my pioneer avh4200dvd i got the player the schoshe panel piece and the wiring harness will i need anything else besides some tools and how does my stop radio and panel piece come off
  2. Aug 24, 2011 at 7:02 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Do you have the jbl system? If not thats all you need. Pop out the ac controls. There will be a couple bolts. I think 10mm. Really easy. Just be careful pulling out the ac controls. don't use a knife or anything that can cut Into the plastic.
  3. Aug 24, 2011 at 7:15 PM
    AustingAnderson20
    Austin
    No i dont have the jbl system what exactly is it anyways
  4. Aug 24, 2011 at 7:25 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    as long as you got the wiring harness for non-JBL your all set...make sure you have zip ties to clear things up and tighten everything it will go in much easier
  5. Aug 24, 2011 at 8:48 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Jbl is the upgraded sound system in Toyota. If you don't have it, make sure you have the normal (non jbl) harness like stated above. That's all you need man.
  6. Aug 25, 2011 at 7:08 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Look through the Audio & Video forum on here. More info then you can shake a stick at.
    BTW, if you want the steering wheel controls to work with the new HU, you'll also need a steering wheel interface control.
