Hooking up New lights.
Discussion in 'Lighting' started by ABregenzer, Feb 16, 2012.
  1. Feb 16, 2012 at 4:21 PM
    ABregenzer
    ABregenzer [OP] Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    So I've got a set of lights behind my grill. I don't know what they are or if they even work. They have all the wires, but they aren't mounted correctly. the PO had them mounted to the radiatior mount some how. My question is, how could I go about making sure they work? If they don't, I'll go ahead and buy some lights later. Could i just hook them up to the battery? :confused:
  2. Feb 17, 2012 at 7:41 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    Follow the wires. No switch anywhere? Pics?
  3. Feb 17, 2012 at 12:33 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    You could hook them directly to the battery, but just for safety's sake I'd put an inline fuse in. If something shorts (easier for a temporary circuit), it'll save yer bacon.
  4. Feb 17, 2012 at 12:55 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. I have touched wires directly to the battery before just to make sure they work though. Not really the best way to go about doing things because if there is a short, you could do some damage to your battery (or yourself). Best/safest way would be to make sure you have continuity from the positive to the negative across the light itself.
    Is it wired in at all? Maybe trace the wires and see if they're set up to plug into a switch somewhere? If you want lights up there eventually anyways, check the wires, make sure everything is connected properly (in-line fuse, relay, etc) run them to a switch and flick them on.
  5. Feb 17, 2012 at 1:28 PM
    BG KY Jets Fan
    BG KY Jets Fan Dagger Taco *****
    Joe
    Bowling Green Ky
    2011 TRD Sport 2WD DC
    Roof Rack, TRD skid plate, TRD cat back exhaust, Pioneer AVIC-930BT, subwoofers, Avid bar, Westin side steps, FLYZEYE strip, and Blacked out Badges. More to come....
