Hopkins Adapter for 2010 Tacoma???????
Discussion in 'Towing' started by GT150, Nov 7, 2009.
  1. Nov 7, 2009 at 7:56 PM
    GT150
    GT150 [OP] Well-Known Member
    Blairsville Ga
    2010 Prerunner V-6
    I just got my 2010 Tacoma Prerunner with a towing Package. I purchased the 7 to 4 wire plug from Walmart and wired my trailer, all lights work. The 7 to 4 wire plug is made by Hopkins and is number 47345. The plug seems loose when I put it in the plug under the hitch.
    Is this the proper Hopkins adapter that I need?
    Thanks for your help
  2. Nov 11, 2009 at 3:04 PM
    roy826
    roy826 Well-Known Member
    Mississippi
    2010 Prerunner TRD Sport DC
    If your truck came with the towing package it should have also come with the converter to 4 pin. Mine did. 2010 Prerunner with towing package. It even said it came with the converter on the window sticker under towing package. Mine was not with the truck salesman had to go looking for it. I would not leave without it.
  3. Nov 11, 2009 at 3:07 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    I tried one from autozone and it didn't work. I went to the stealership and bought the toyota one it was only like $8. It works fine.
  4. Nov 11, 2009 at 4:39 PM
    GT150
    Blairsville Ga
    2010 Prerunner V-6
    Amaes,
    Does the toyota one fit in tight, the hopkins works but I think it would fall out without being zipped tied on.
    Thanks for your response
    mike
  5. Nov 11, 2009 at 4:54 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    I think you will find that the plugin cover has a lip on it that prevents the plug from coming out. At least mine does. I had the same concern when I used mine for the first time. After crawling under there to get a better look I felt better about the situation. Plug your adapter in and pull on it to see if it will come out...
  6. Nov 11, 2009 at 5:06 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    It fits in pretty snug
