Horn and TPMS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sawed off, Feb 7, 2016.
  1. Feb 7, 2016 at 12:35 PM
    sawed off
    sawed off [OP] Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    While I was tinkering today I noticed that the horn on my 2015 Tacoma has a shield over it. I removed it and it sounds better to me. The tire pressure on all 4 tires was about 23 psi and I did not have tpms light on, just curious if anyone knows what psi it turns on as I don't feel like letting air out to answer own question.
  2. Feb 7, 2016 at 12:53 PM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
    TPMS light depends on what the tire pressure was when it was last set. Check your owners manual.
  3. Feb 7, 2016 at 12:54 PM
    sawed off
    Randy
    Idaho
    The light never set. I will check manual
  4. Feb 7, 2016 at 12:56 PM
    GroupW
    Mark
    Arizona
    Red TX
    The reset sequence is something like:
    Key off
    Hold TPMS button
    Key to on
    Wait until the light blinks 3 times.
    Now its set to your current pressure.
  5. Feb 7, 2016 at 5:33 PM
    sawed off
    Randy
    Idaho
    Thank you, so basically this system allows the driver to set his desired tire pressure.
  6. Feb 7, 2016 at 8:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes.
