Horrible brake squealing
Discussion in '1st Gen. Tacomas (1995-2004)' started by hardtaco, Mar 6, 2009.
  1. Mar 6, 2009 at 4:28 AM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I am experiencing horrible brake squealing, when slight pressure is applied to my brake pedal. My brake pads and shoes are fine. Fronts were changed out around a year ago, and the rears at that time had around 80% meat left. I have visually inspected them both recently, and there is plenty of meat left. It's embarasing rollin up to a light, squealin like a pig. It happens when slight pressure is applied to the pedal, when you apply heavy pressure, it's gone. Anyone else squeelin like a pig while braking? What is the fix for this? It's a 2004 PreRunner D-Cab.
  2. Mar 6, 2009 at 6:17 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Brake Glazing maybe?? Try some brake cleaner and see what it does. I'm sure there will be more ideas.
  3. Mar 6, 2009 at 6:23 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    Mine did that when my pads went bad. I would have a mechanic look at it
  4. Mar 6, 2009 at 7:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    You have brake dust built up on the back of the pad.
    You need to reomve them, clean them, and apply this
    .....like this (not a tacoma pic, you get the idea)
  5. Mar 6, 2009 at 8:33 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    98tacoma is right.,
    add to that Sand the pads with sand paper. 80 to 100 grit, does nto realy matter.
    you just want to ruff them up a bit.
    Also what pads do yo u have? are they OEM or a Racing pad?
    If they are non oem then you may have a pad the needs more heat to work.
    my Race pads squeak when cold and when to light of pressure is applied.
    To fix i brake later and harder....
    But normal pads my have over heated a bit, try what you have seen.
    Also clean the mounting points of the pads, hardware, and caliper and lube the sliders.
    Our brakes need to be check and adjusted ever 5k with tire roation or they will wearout sooner than needed.
    I get between 60K and 80K on front disc pads when doing this.
    and never replace rear shoes. I just adjust and clean...
  6. Mar 6, 2009 at 10:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'll vouche for the disc brake quiet....
    I remember on my 96 - the pads had a steal shim thing on the inside of the pad. When I replaced my pads, I took these shims off the old pads and put them on the new pads.....
    Do you know if you have these shims on the new pads?
    If not.... like 98tacoma27 had already mentioned, applying *disc brake quiet* material on the inside of the pads. You can also get the stuff in a spray can (that's what I use).
  7. Mar 6, 2009 at 10:12 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I had the same thing happen to me, and when I had them inspected it was just a build up of brake dust. But I just resently changed my pads and now there silent as can be.:)
    I would try what 98T has sugested and see if it helps.
  8. Mar 6, 2009 at 10:13 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    So this quieting material actually goes on the back side of the pad, correct? Not the side that would come in contact with the rotor obviously........
  9. Mar 6, 2009 at 10:13 AM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    are the toyota pads? because mine were doing that a few weeks ago and my local shop toldme that any other brake pad on a tacoma would squeeeaal.....my sounded terrible. cost me around 50 bucks for the pads
  10. Mar 6, 2009 at 10:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, the part of the pad that does not touch the rotor is where the quiet goes.
  11. Mar 6, 2009 at 11:37 AM
    Janster
    Jandy
    Lancaster, PA
    Yes
    Comes in contact with the piston - NOT the rotor.
  12. Mar 6, 2009 at 1:37 PM
    ubermx5
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    With the large picture above; showing how to install it this statement scares me...
    :eek::eek::eek::eek::eek::eek:
  13. Mar 7, 2009 at 4:34 AM
    Janster
    Jandy
    Lancaster, PA
    Why is that?
  14. Mar 7, 2009 at 10:48 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Yeah, why IS that? I don't get it.
  15. Mar 7, 2009 at 11:06 AM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    you might want to check to see if you have the backing plates on the pads. some people replace their pads with aftermarket and throw away their backing plates. they will help the squeal cause of less vibration. but i think your only supposed to use them with factory pads.
  16. Mar 17, 2009 at 4:59 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Can anyone confirm if you ONLY use the backing plates with Toyota factory brake pads, and NOT use them with aftermarket brake pads??? I need to seriously get rid of this embarrasing squeal!
  17. Mar 17, 2009 at 7:55 PM
    Janster
    Jandy
    Lancaster, PA
    Does the aftermarket pads come with backing plates?
    If the aftermarket pads already have backing plates, then DO NOT use another set of backing plates. Don't stack backing plates.
    You could use the original backing plates if you can integrate them to the aftermarket pads. When doing my 96 (it's been a long time), I used the original backing plates on my new pads. The pads I put in were factory replacements.
  18. Mar 18, 2009 at 2:46 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    My aftermarket pads did not come with the plates, but I installed the plates from the originals onto the the new pads. Now, if I put some of that anti squeal compound on, will it go sandwiched in between the pad and backing plate, or will it go on the back of the backing plate? I just want to be done with this issue...............
  19. Mar 18, 2009 at 3:55 AM
    Janster
    Jandy
    Lancaster, PA
    Good question...
    Technically, since you have the plates - you don't need the anti-squeel compound. They both do the same thing.
    But it certainly won't hurt anything to apply anti-squeel if you want. I'm not certain about 'where' to put the compound, but if It were me...I'd put it on the outside of the plate (directly in contact with piston). That way, the plate can still do its job as intended without the compound being in the way (did that make sense)?
  20. Mar 18, 2009 at 5:26 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Yes, thanks!
