Horrible gas mileage in sub zero temperatures
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 03f5sp, Dec 31, 2013.
  1. Dec 31, 2013 at 12:29 PM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I know there's quite a few mpg threads but I haven't found one regarding cold temps. Anyway..
    It's been below 0*F the past few days and it seems like I've been getting less than 10 mpg. I understand that low temps reduce gas mileage, but should it really be this terrible? I've got a home stock TRD dcsb V6. Thanks in advance, Bill.
  2. Dec 31, 2013 at 12:33 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Shouldn't be the case if you don't spend too long warming up the truck. Make sure your tire pressure hasn't fallen low because of the cold. Remember the tires lose 1 psi for each 10 deg F drop.
    How are you measuring mpgs, odometer+pump reading between fill-ups, or by OBDII output?
  3. Dec 31, 2013 at 12:41 PM
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    If most of your trips are shorter than say, 10 miles, that number isn't surprising. One also idles a little more in cold temps, and an idling truck gets 0mpg. My consumption usually goes down 20% in the wintertime.
  4. Dec 31, 2013 at 1:04 PM
    03f5sp
    Bill
    Wisconsin
    I usually let it idle for maybe four minutes in the morning so it get get to 50*+ before I drive off. Most of my driving is less than ten miles. Judging by the odometer and fuel gauge I know that my mileage is way way lower than before, like 1/2 my normal mpg.
  5. Dec 31, 2013 at 1:06 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Ditto
  6. Dec 31, 2013 at 2:08 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I always thought that cold air temps actually improve 'performace' (milage may be different) on an internal combustion engine..... the air is more dense that warm air.
    .... True?? Anyone??
  7. Dec 31, 2013 at 2:16 PM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Our trucks are heavy on fuel especially cold starting. And take much longer to get warmed up if your driving short distance. Basically the colder the engine temp the more fuel you will consume. Theres nothing that is going to cure it. My best suggestion is to get a ultra or scan gauge to monitor temps, average mpg, etc. Then you'll have a better idea whats going on.
  8. Dec 31, 2013 at 2:24 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Yes, performance does improve with the cold dense air.
    Its also pretty normal for milage to bomb with short trips in cold temps - richer mixture and the fact that it will stay in open loop pretty much the entire trip as the coolant temp will barely reach normal by the time its shut off. Combine that with tire pressure dropping off in the cold, cold (stiff) tires, and the stiff, cold gear oil in the diff(s), t-case if a 4x4, and transmission, and 0mpg warm-up time, its a noticable difference. Switching drivetrain fluids to synthetic helps a wee bit. Personally, I've seen a 30%+ increase in fuel consumption with short trips in the cold. A block heater with a timer helps some too, have it come on 3 hours before you're going to start the truck.
  9. Dec 31, 2013 at 2:33 PM
    RogerRZ
    According to my scangauge, my truck is only in open loop mode for the first two miles or so, no matter how cold the weather.
    Don't forget, even if the motor "might" be more efficient in sub zero temperature, consider how thick all the lubricants are in those temps. Every bearing on the truck is almost frozen solid...
  10. Dec 31, 2013 at 3:44 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Cold temps should not lower MPG. In fact cold temps should increase the MPG because the intake air is colder which increases compression. Long warm ups will lower MPG. Also if your thermostat is bad and not bringing the truck up to manufacture recommended Temp the truck CPU will stay in warm up mode which uses more gas.
    Here is an article about a FJ having this problem
    http://www.fjcruiserforums.com/forums/engine-performance/119773-fuel-mileage.html
  11. Dec 31, 2013 at 3:59 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    It's normal in all vehicles for mpg to drop in sub zero temps.
  12. Dec 31, 2013 at 4:08 PM
    tsb
    tsb 2018 National Champions
    Clemson Tigers
    '14 4X4 DBCSB TRD OR
    N-FAB nurfs, ARE cover, Gentex mirror, 20% tint
    you are correct sir - cold air improves performance and requires more fuel to maintain the a/f ratio. the a/f becomes lean / leaner as the air becomes colder. The ECU will add / subtract fuel to maintain a target a/f ratio.
    Cold air requires more fuel and hot air requires less to maintain the same a/f ratio. but there is much more than cold air at play in sub zero temps. the ECU will lower the a/f requiring even more fuel, retard timing, etc..
  13. Dec 31, 2013 at 6:12 PM
    03f5sp
    Bill
    Wisconsin
    I've currently got my phone app to show engine temp, intake temp, a/f ratio, MAF, and a few others. All readings are normal. I just added the average mpg meter so I'll keep an eye on that.
    On a side note, I highley recommend the phone app 'Torque'. The app is $6 and the OBD2 Bluetooth adapter was $30. It allows you to setup 5 pages of reading to setup, records min/ max, and has 100+ readings to choose from(not all work with our truck).
  14. Dec 31, 2013 at 7:24 PM
    brown33
    brown33 Member
    levi
    Fairbanks
    sr5
    This last week it was around -45 in Fairbanks I'm lucky to get 150miles out of a tank. Thinking of driving my old 4runner when it gets cold.
  15. Dec 31, 2013 at 7:27 PM
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    My 07 4.0 is thirsty year round the fuel gauge is constantly on the move it is over maintained with synthetic everything. Always has clean everything and new plugs all the time. I run my Grandprix to and from work 25-30 mpg and use the Tacoma when I need to I love the truck but the mileage is awful and it took me quite some time to fess up and realize it is what it is.
  16. Dec 31, 2013 at 7:30 PM
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    Just filled up my 06 sport tonight and checked my MPG a whopping 12mpg... It's been cold past few days though, had 182 miles on the tank... And 61K. On odometer.... I always see a decrease in the winter...
  17. Dec 31, 2013 at 7:34 PM
    RCKT82
    RCKT82 Well-Known Member
    Mid-West U.S.
    2013 PreRunner AC SR5 V6
    My truck ran 19mpg during the summer months, right now it's running around 16mpg... My GM mpg is worse in the winter also.
    tsb makes a great point on the reasoning.
    I've also heard some posters state that fuel mixes are changed with regards to additives since fuel is less volatile in colder temps, but I haven't researched the validity of oil companies actually doing so.
  18. Dec 31, 2013 at 8:55 PM
    AKTacoParty
    AKTacoParty Well-Known Member
    Jake
    Astoria, OR
    2013 DCLB
    885s, Dakars, Bilsteins, Allpro Sliders, Archive Garage Hammer Hangers, Wheelers Ubolt flip, super bumps, RCI front skid
    I learned the other day that when you run the defrost the a/c runs and therefore reduces your mpg's even more. I'm actually in the process of gauging my mpg's while limiting my use of defrost to see if it even changes at all. I also recently changed to all synthetic in the diffs and transfer case, seems smoother but we'll see what happens.
  19. Jan 1, 2014 at 1:15 AM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I personally understand how the mileage goes down when cold, many factors.
    But the only reason I bought my truck was for how it performs in the snow and cold
    not for the MPG it gets.
    no matter how bad the MPG, its worth it knowing I will make it home safe and sound
    in the worst of winter conditions.
  20. Jan 1, 2014 at 3:20 AM
    MQQSE
    MQQSE Bannable Galloot
    Rob III
    Palmer, Alaska
    "Stitch" Still Stock Concept Truck
    Shtuff
    I average 20MPG in Summer 19 MPG in Winter with my '07 2.7L.
    Summer I get tanks from 20 to 21 MPG.
    Except towing gets 14 to 15 MPG. (3200 lbs / single axle / 6' x 10' enclosed box trailer)
    Winter I get tanks from 18 to 20MPG.
    Single digit positive and subzero gets 18.X MPG.
    Warmer teens and 20s (fahrenheit) gets 19 to 20 MPG.
    EDIT: No complaints.
