Horrible sound from front suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Devux, Nov 24, 2011.
  1. Nov 24, 2011 at 9:17 PM
    Devux
    Devux [OP] The StarMan
    Devin
    Las Vegas, NV
    2011 PreRunner
    Stone stock.
    Hey guys, my 2011 Tacoma makes a strange (horrible) sound somewhere from the front end when I go over some speed bumps. It sounds like a crunch and I cringe every time it happens. Truck is stone stock PreRunner, I know I'm not dragging the skid plate and I know the tires aren't rubbing anything. I don't haul arse over speed bumps, on the contrary I crawl over them to avoid hearing this sound. My only guess is the suspension hitting the compression limit (some sort of bumpstop?) I check frequently and have yet to find anything that looked damaged. Anyone else experiencing this?
  2. Nov 24, 2011 at 9:32 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    I would take it back to the dealer and explain the problem, this doesn't sound good. Welcome to TW!
  3. Nov 24, 2011 at 9:40 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    If the speed bumps are big enough they could be hitting the mud flaps
  4. Nov 24, 2011 at 9:44 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    This.
  5. Nov 24, 2011 at 10:22 PM
    Syncros
    Syncros Well-Known Member
    Mud flaps, swap them out for soft ones or cut them shorter before you damage the fender flares.
  6. Nov 24, 2011 at 10:27 PM
    Johns Taco
    Albuquerque, NM
    Didntn't think of this, take them off the front and see if the problem is gone.
  7. Nov 24, 2011 at 10:37 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    The bottom edges will be abraded if they have been dragging.
    As most here know, the flaps are too long, especially the fronts.
    I took about 4-1/2" or so off my fronts to match the rear spacing for now.
    I used a tin snip for the rough cut and finished them with a sanding block.
    They look OEM. They were done off the vehicle.
  8. Nov 24, 2011 at 10:38 PM
    OZ-T
    OZ-T You chose ... wisely
    Peter North
    British Columbia
    Trim the flaps
  9. Nov 24, 2011 at 10:53 PM
    monkeytaco
    monkeytaco Well-Known Member
    Charles
    Austin, TX
    2012 Mag Grey DCSB V6 4x4 AT Sport
    It probably is the flaps, it's amazing how much stuff those things will hit. They are waaaay to long from the factory.
  10. Nov 26, 2011 at 11:14 AM
    Devux
    Devin
    Las Vegas, NV
    2011 PreRunner
    Stone stock.
    Thanks for the tip lads! The bottom of the front mudflaps were all roughed up from dragging the speedbumps. I will cut them down to match the rear flaps. I would have never thought of checking them.
  11. Nov 26, 2011 at 11:21 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Awesome. Another quick solution brought to you by TW!
    Don't be a stranger. This place is full of good ideas of things you can do to your truck. Have a look at the mod(ification) posts on here :)
    Welcome to TW!
  12. Nov 26, 2011 at 11:23 AM
    T-Rex266
    T-Rex266 Moderator Moderator
    Just take the flaps off :)
  13. Nov 26, 2011 at 1:05 PM
    jflan
    Vancouver, WA
    Here's how I did mine...
    Get the truck on a level slab and measure the clearance from the REAR flaps to the ground.
    So far I'm happy with my rear flap clearance. The 4x4 label is in the wrong place to allow non-ghetto trimming, IMO. A trimmed rear Pre-runner flap would be my solution to shorter rear flaps. Maybe the new Husky product, maybe not.
    Take that clearance dimension and apply it to the front flaps.
    That's your cut mark.
    I think I took about 4-1/2" off of mine. I can't remember the clearance number.
    Now take both front flaps off. There is a combo of bolts and plastic push rivets. I tried to finesse the push rivets but it went better when I got a little rougher with them. I broke a couple with my "finesse method".
    The Toyota store has more.
    I used a white "China" marker and squared across at the new cut line.
    Then I used the other flap to trace the proper radii onto the new cut line.
    I used a good tin snip (Wiss) to make the rough cut, about a shy 1/8" from the cut line.
    Then I used a good sanding block (made from a piece of 1x and belt sander belt) to do the final shaping.
    Reinstall the flaps.
  14. Nov 26, 2011 at 1:19 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Have someone watch you go over a speed bump lol
  15. Nov 26, 2011 at 2:08 PM
    Devux
    Devin
    Las Vegas, NV
    2011 PreRunner
    Stone stock.
    Yeah, I broke a few before I figured out a good method. I think it looks better without the mudflaps, but I will cut and re-install them before I go flying down the dirt trails out here. Don't want dings from rocks. :)
  16. Nov 26, 2011 at 7:05 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    Well that was an easy fix hopefully you won't have anymore issues
  17. Nov 27, 2011 at 4:40 AM
    toytaco11
    toytaco11 Well-Known Member
    Albuquerque
    11 TRD 4x4 lwb doublecab
    coming soon!
    I have the exact same issue, bone stock right now and when I go over speed bumps at low speed there's this loud crunch/squeak. I've inspected it everytime and don't see anything wrong, my thought was maybe the coils is making the noise when it compresses or the inside of the tire rubbing on the UCA.
    Anyhow, I took my truck in for my first oil change and explained my issue with the crunch noise over the speed bumps, I also mentioned I wanted the rear leaf TSB done, they gave me no hassles and ordered the parts for the rear leafs and said when I bring it in to do the TSB they will address the front noise issue and inspect further. I hope they can find an explanation because it really $ucks going over speed bumps with this loud crunch noise. I will let you know what they tell me , in the meantime if you hear anything or figure out what is causing it let me know.
  18. Nov 27, 2011 at 5:20 AM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    If you have the exact same issue as the OP, you may benefit from the exact same fix that was repeated in half a dozen posts. :rolleyes: If you already ruled out the flaps it's worth mentioning, as your problem is then an entirely different issue than the OPs.
  19. Nov 28, 2011 at 4:32 AM
    toytaco11
    Albuquerque
    coming soon!
    I wouldn't mention it if it was the mudflaps, I'm not retarded.
    It's NOT the mudflaps!!!!!!
  20. Nov 28, 2011 at 6:30 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Don't take offense, man.
    You sound so sure of yourself, but how do you know?
    Fact is, the very low hanging front factory mud-flaps scrape on speed-bumps making a crazy suspension-broken sounding noise. :eek:
    Takes a lot of TW members by surprise, including me, when I first got my truck.
    There are no other common suspension noises/problems that manifest themselves on a new unmodified taco. So if that's not it, the dealer's going to have to run it down as a warranty issue.
