Horrible vibration not normal!! Need help!
Discussion in 'Technical Chat' started by way2fast, Feb 4, 2012.
  1. Feb 4, 2012 at 8:19 AM
    way2fast
    way2fast [OP] Well-Known Member
    Ethan
    Wichita Falls, TX
    07 DC TRD Sport SR5 PreRunner
    2.5 King resi c.o., 2.0 fox piggys, deaver j66s, bhlm, grillcraft,
    I was pulling up to my house last night and outta no where the truck started vibrating extremely bad so I stop. I take off and hear a squeaking nose and can't locate it. I can drive for a lil and outta nowhere it starts vibrating bad, the passenger seat is shaking front to back horribly and I can barely hold on to the steering wheel. Im usually good with this kind of stuff but I can't find anything out of place or unusual. Please help
  2. Feb 4, 2012 at 8:48 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Damn....could be anything. Something has definetly come loose. I had a spring perch break loose from the axle tube once on a Jeep that did this. The whole vehicle was shaking & vibrating....bad thing is, the break point was hard to notice.
  3. Feb 4, 2012 at 8:51 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    First easy check to do is, check your U-joints and inspect you rear driveshaft for lateral play. Your center support bearing is housed by a rubber bushing, so it should have a little play to absorb some shock.
  4. Feb 4, 2012 at 8:54 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Is your truck lifted or does it have stock suspension?
    U-joint?
  5. Feb 4, 2012 at 8:55 AM
    way2fast
    Ethan
    Wichita Falls, TX
    I looked at that. How much play should it have exactly? I can move it what I think is quite a bit but this is the only vehicle ive had with a carrier bearing, im not sure if its the rubber moving or thd bearing in the rubber
  6. Feb 4, 2012 at 8:59 AM
    way2fast
    Ethan
    Wichita Falls, TX
    Yes I bought it with this stupid lift already on it a few months ago and im waiting for my mid travel to show up already lol. The bearing is spaced down im guessing to help with the driveline angle cause of the lift
  7. Feb 4, 2012 at 9:00 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    from what i've read from previous threads, this could be a "death wobble"?
  8. Feb 4, 2012 at 9:04 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Couldn't tell ya how much play the bushing has right off the bat. The best way I could tell ya how to check if the center bearing has play is to jack under where the U-joint is to support the shaft by the bearing then grasp the other side to see if it has any play. I don't know any other way to do it with out disassembling it. I just checked my bushing play and it has about .25" of up and down play, and maybe .175" side to side.
  9. Feb 4, 2012 at 9:06 AM
    way2fast
    Ethan
    Wichita Falls, TX
    Well thats a good way to explain it. Do you know the culprit of it?
  10. Feb 4, 2012 at 9:11 AM
    way2fast
    Ethan
    Wichita Falls, TX
    I
    I think mine might have more. ill check it better when I get back from lunch and let you know how much ive got. Im thinking about putting it on jack stands and running it to see if i can find it but im scared if it shakes like it did it might fall off
  11. Feb 4, 2012 at 9:12 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    thats not death wobble. death wobble is when a vehicle goes over a surface and the vehicles steering/suspension cannot get it to recover from uneven road surfaces. more common in jeeps/chrysler
  12. Feb 4, 2012 at 9:17 AM
    way2fast
    Ethan
    Wichita Falls, TX
    Yea I know what it is. I know this isnt it but its a damn good way to explain it
  13. Feb 4, 2012 at 9:20 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I bet center bearing. When it went on my old truck there was like 5" of "play" I can't believe the drive shafts didn't fall out. [​IMG][​IMG]
  14. Feb 4, 2012 at 9:25 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    For safety, on as flat of a surface as possible, put the jack stands under the rear axle as close to the leaf springs as possible. Chock at least one of the front wheels with blocks. When you put the trans in gear, only put it in 1st or reverse just in case(highly unlikely though) but just in case it does come off the stands, it won't go that far. Even better, is to have a second person to ease on the gas, at that point you can have the trans in D. You can hit the gas with your hand and look under the truck at the same time to see what's going on. Other guys have strapped a camera under the truck to see and hear what's happening, and there are U tube vids of this as well to cross reference. The jack stand method is never recomended, so use your own discretion, and please be safe. Post a vid if you can.
  15. Feb 4, 2012 at 9:29 AM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
  16. Feb 4, 2012 at 9:34 AM
    way2fast
    Ethan
    Wichita Falls, TX
    Im going to put it on thd frame lift at work and my friend is gonna help so ill let ya know what I find out
  17. Feb 4, 2012 at 9:41 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Just get under your truck, grab the drive shaft and shake it. If it moves more than a very tiny amount.....welcome to the center bearing replacement club.
  18. Feb 4, 2012 at 10:07 AM
    way2fast
    Ethan
    Wichita Falls, TX
    Yep just joined lol and it already got more play then it had earlier. Any idea what they cost
  19. Feb 4, 2012 at 10:33 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
  20. Feb 4, 2012 at 10:41 AM
    way2fast
    Ethan
    Wichita Falls, TX
    The dealer wants 206 dollars! is a one piece drive shaft worth the extra hundred bucks to not have to have this problem again?
