hot wire hook up for led in footwells 2012
Discussion in 'Lighting' started by tac268, Jan 16, 2013.
  1. Jan 16, 2013 at 11:05 AM
    tac268
    tac268 [OP] Active Member
    Henry
    South Carolina
    12 TRD Prerunner Double Cab
    Looking for a reliable hook up for two led lights for passenger and driver footwell for my 2012 tacoma dc trd. what is your input. something simple. not much electrically inclined. thanks
  2. Jan 16, 2013 at 11:17 AM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Connect it your fuse box in the cab. Can add a switch if you want control of them.
  3. Jan 16, 2013 at 11:19 AM
    tac268
    Henry
    South Carolina
    so just use a common ground for the black wire and how would i install the hot wires into the fuse box?
  4. Jan 16, 2013 at 11:21 AM
    tac268
    Henry
    South Carolina
    i thought about buying a fuse tap to use to be more stable. what do you think?
  5. Jan 16, 2013 at 11:21 AM
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    Yea ground the negative to your frame. You can get a fuse splicer that I've seen on here but I usually just let the wires the hole with the fuse.
    Yes fuse tap would be best
  6. Jan 16, 2013 at 11:25 AM
    FastEddie
    FastEddie Well-Known Member
    MD
    2012 super white access cab, base model
  7. Jan 16, 2013 at 11:25 AM
    tac268
    Henry
    South Carolina
    ok. thanks. You have been a great help. Thankyou.
  8. Jan 16, 2013 at 11:44 AM
    Me Likey TRD
    Me Likey TRD Well-Known Member
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    Toytec Ultimate w/Dakar leaf packs, Michilin 265/75/16 LTX AT2, FJ Trail Team replica wheels, Access Ltd bed cover, Katzkin leather, Brute Force rear bumper, Relentless Fab front bumper, Beefed sliders
    Here's what I did just last Saturday:
    Mounted an LED module using double-sided tape to the side of plastic venting under each foot well.
    Something similar to this:
    Ran wires through center of console to HVAC controls and tapped them into the dash light wires.
    This may be a bit more involved than you're interested in - but I think it would be a fairly simple project for most.
  9. Jan 16, 2013 at 11:48 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I added someone for those timesi drop stuff on the floor a night...they're tapped into my parking light fuse by an add a fuse
    Also have a switch to turn on whenever I want
  10. Jan 20, 2013 at 10:05 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    how to tie in with the door ajar switch?
  11. Jan 20, 2013 at 10:11 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Easy, negative to ground and positive tapped to the plug right under the dash
  12. Jan 7, 2014 at 3:53 PM
    JDK12688
    JDK12688 Member
    Jay
    Vicksburg, MS
    Tacoma TRD Sport
    in the ac control cluster which is the hot wire?
