How 2 Disable VSC?
Discussion in 'Performance and Tuning' started by TacoOwner, Apr 8, 2013.
  1. Apr 8, 2013 at 1:10 PM
    TacoOwner
    TacoOwner [OP] Member
    Pat
    California
    Dbl Cab Short Bed 4X4
    Pro-Comp 6" Lift/33" Wranglers/Detroit TrueTrac Diff
    Can anyone tell me how to permanently disabled the VSC on a 2011 4X4 or comparable? Thanks!
  2. Apr 9, 2013 at 2:15 AM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    Have you tried holding the button down for 5 secs? That usually makes VSC system shut off completely
    Or permanently as in you don't ever want it to turn on again when you turn the truck on and off? lol if you want that then im clueless
  3. Apr 9, 2013 at 8:34 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ABS bypass switch will kill ABS and VSC
  4. Apr 9, 2013 at 9:20 AM
    TacoOwner
    Pat
    California
    Yes I am sick of pushing the button. Often I am in deep sand trouble when I remember I should have done it.
    Permanently is what I want.
    OZ-T Can you elaborate? Where do I find the bypass and is it as simple as a unplug? Will this cause warning lights and trouble codes a plenty?
    Thanks for the info.
  5. Apr 9, 2013 at 11:34 AM
    OZ-T
    Peter North
    British Columbia
    What model Tacoma do you have , there are a few different mods
  6. Apr 9, 2013 at 11:44 AM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
  7. Apr 9, 2013 at 6:03 PM
    TacoOwner
    Pat
    California
    Mine is; No TRD, No Locker, yes LSD, Manual Trans
    I have buzzed thru the tread you linked. Looks like I can sort out what I need from there. Once I shut this soccer-mom crap down, get my TrueTrac installed, the Taco should suit my needs very well. Thanks for the help!
  8. Apr 9, 2013 at 6:11 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Since it's a 2011 4x4 w/ no locker, you can do the mods in my writeup. ABS killswitch will kill 2 birds with 1 stone, and the YWM will enable TRAC in 4LO (ABS has to enabled to make it work).
  9. Apr 19, 2013 at 9:29 AM
    TacoOwner
    Pat
    California
    Got the YWM done, as well as the fog light mod. Thanks for the help guys!
