How air goes thru your engine.....(basic)
Discussion in 'Technical Chat' started by chris4x4, Nov 30, 2008.
  1. Mar 3, 2009 at 8:40 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I'm doing a little bit of research now. At the moment, I think the runners are designed primarily to accommodate the air flow bounce back that occurs when the intake valve closes. I'm always open to being wrong(I did agree to get married) If you have any sources, I would love to read them.
    I agree.
    I know you know, I just thought it was a good thing to point out the difference in the air flows through a S/C vs. T/C engine.
    Seems like a good idea to me...
    Actually, most manufacturers do that, just not to that extent. Look up the EGR valve.
  2. Mar 3, 2009 at 8:53 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    They are for that. BUT, if the air flow is turbulant, the pulses wont be able to be as easily tuned, if at all. One of the reasons manufactures have switched from cast aluminum intake manifolds to injection molded plastic ones (other than it IS less expensive), is that the runners can be made smoother, creating less turbulence. if you look closely at the bends in a modern intake, you will see that they are a little flatter than the straight parts of the intake. This is to avoid the tubulence formed when air goes around a turn. The air tward the "out side", if you will, of the bend is going to accelerate faster than the air tward the inside of the bend, thus causeing turbulence in the stream. By flattening it, all the air (more or less) maintains the same velocity. This same thing can be used in the exhaust, as bends in the pipe cause turbulence, and slow down the exhaust gasses. Seems only 1 company has done this with FANTASTIC results, but there is a patent on it. http://www.micronexhaust.com/store/prodserpent.htm
  3. Mar 3, 2009 at 8:54 AM
    MacTaco
    MacTaco Mustache May
    Pensacola, Florida
    06 Indigo, Lifted, Flowmaster
    Skyjacker 3" Lift, 285/75/R16 Toyo M/T tires/ Eagle Alloy Wheels, Flowmaster 50 Series, Pioneer Din Head Unit, Viper Alarm/Remote Start System, Debadged, DT Headers, True Flow Intake
    Kinda like farting into a tube leading to your mouth.
  4. Mar 3, 2009 at 8:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Whats wrong with that?
  5. Mar 3, 2009 at 8:58 AM
    MacTaco
    Pensacola, Florida
  6. Mar 3, 2009 at 9:13 AM
    lsocoee
    Hotdog
    Wet Okole Underwear
    I guess this all goes back to treating laminar and turbulent as absolute terms. Me saying it isn't laminar and Chris saying it is, we might be saying the same things. My definition of laminar is that there is no turbulence. I'm thinking Chris's definition is that it is mostly smooth flow. (correct?)
    I understand what and why you have said about the laminar flow-that laminar flow makes the intake pulses easier to predict and calculate. I see that testing is really the only way to accurately and efficiently design an intake manifold.
    I disagree that the design of intake runners is to increase laminar flow. I believe that the design of the runners is largely defined by the desired power band.
  7. Mar 3, 2009 at 9:14 AM
    lsocoee
    Hotdog
    Wet Okole Underwear
    are you trying to say that you don't sniff your own farts???
    yeah!
  8. Mar 3, 2009 at 9:16 AM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You have to smell the "exhaust". Good indication of your tuning.
  9. Mar 3, 2009 at 9:19 AM
    MacTaco
    Pensacola, Florida
    Hahahahahahaha :poking:
  10. Mar 3, 2009 at 9:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well.....ok. being as the air stream will never be 100% laminar.
    Originally, yes. Not long ago, manufactures started useing them (designing) to also smooth the air flow into the combustion chamber.
  11. Mar 3, 2009 at 9:48 AM
    lsocoee
    Hotdog
    Wet Okole Underwear
    OK. Good to know. I concede.
  12. Mar 3, 2009 at 9:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct! that would be your FSR (Fart Smell Ratio). Poor tuning is noticed when checking the FSR you find a bit of S (shit) comming out of the pipe when testing for the FSR. This would lead to a FS/SR (Fart Smell/Shit Ratio), in which case, changeing your diet may be in order.....or seeing a Dr.
  13. Mar 3, 2009 at 9:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Me too.. My head hurts, and I cant get ahold of any of my friends to help me out. :(
  14. Mar 3, 2009 at 9:53 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    .....making a Throttle Body Spacer (TBS) nothing more than a $40ish trinket.
  15. Mar 3, 2009 at 9:56 AM
    #35
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yepo! TBS does hold paper down VERY well, however. :)
  16. Mar 3, 2009 at 9:58 AM
    #36
    sonjay
    sonjay Well-Known Member
    Great write-up chris!
  17. Mar 3, 2009 at 9:59 AM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ty, Sir! :proposetoast:
  18. Apr 14, 2009 at 7:39 PM
    #38
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    This is the first time I have seen this. Who know iso could make a... a...intelligent post?
  19. Feb 27, 2010 at 3:29 AM
    #39
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    some very good points in this article. very well worded chris. I tried to give you rep.. but apparently I have to give more rep to other people before I can give some to you again. :laugh:
    A few others that can be added to the list, is the pulse rebound that happens after a valve shuts.
    On the 05+ tacomas the air surge tank has a butterfly valve that adjusts the runner length to optimize that pulse rebound to provide optimal efficiency through the full RPM band. This is essentially the theory behind the throttle body spacer, as the throttle body will act as the rebound point on the intake, where the collector is the rebound on the exhaust end.
    Then we can talk about backpressure and the importance of proper header design.
    You can also dive into diameter changes, port matching, and the Bernoulli's Principle as well (purpose behind mandrel bends in exhaust).
    Lots of fun stuff... doesn't everybody just love to learn about the engineering that goes into what we all assumed was just "some path to get air from outside to the motor, and the the motor back to the outside"
    PS.. what happened to getting this as a sticky..
  20. Feb 27, 2010 at 5:10 AM
    #40
    2003 TRD Man
    2003 TRD Man Well-Known Member
    Edison N.J.
    03 TRD automatic
    Chris-- Great Write Up----U THE MAN :)
