How and when to use Auto Lsd/trac off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Branmar96, Jan 15, 2021.
  1. Jan 15, 2021 at 6:36 AM
    Branmar96
    Branmar96 [OP] New Member
    2020 Tacoma sr5
    From what I’ve heard all the new Tacoma’s come with this feature but from doing research it’s supposed to get you unstuck whenever you’re stuck in snow, mud etc, to turn on this feature you have to hit the trac control button, the auto Lsd light should come on but from what I’ve read the trac control is never completely turned off, for that you have to hold the butting down for at least 5 seconds then the trac off comes off, my question is what to use in a situation where I become stuck like in mud ? Do I just tap the button once and turn on auto lsd or do I hold it down to completely turn off the trac? It’s kinda confusing Btw I have a 2019 dc 2wd
  2. Jan 15, 2021 at 7:17 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
  3. Jan 15, 2021 at 7:18 AM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
  4. Jan 15, 2021 at 7:19 AM
    Tacowin1013
  5. Jan 15, 2021 at 9:11 AM
    ezatnova
    ezatnova Artax
    West Chester, PA
    21 DC TRD OR - Voodoo
    Wildpeak 265/75/16, Headstrong Progressive AAL, 5100's w Emu 885s
    Looked like a bunch of failed attempts to get out using 4hi and one successful try in 4lo. Not sure why he wouldn’t have tried 4lo with MTS on sand way sooner?
  6. Jan 15, 2021 at 9:13 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    its for doing burnouts
    philth and vicali like this.
  7. Jan 15, 2021 at 2:01 PM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2019 TRD-OR AC
    I was impeded by 1/2ft of snow, the second I went into it. Similar happened in some slick dirt w/incline.
    Turned off the traction control, and magicaly I had standard 4wd again.
    If your going into the dirt or snow off-road, I would turn it off or else one wheel will "slip" and the nanny features will go off, causing you to get "stuck."
