How are you fixing the air intake rubbing/ vibration noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PeteH, Jan 19, 2011.
  1. Jan 19, 2011 at 7:16 AM
    PeteH
    PeteH [OP] Well-Known Member
    Hi,
    As of last saturday, I am the proud new owner of an 07 Tacoma DC,TRDsport. I noticed on monday morning that there was an annoying rubbing/vibration sound coming from the front passengers side of the engine compartment. After doing a search here it seems that the noise could be coming from either the air intake where it goes into the inner fender or the y- pipe after the cats being loose.
    I have checked both areas myself and found the springs and nuts on the exhaust to be very tight and soild. The air intake has some slight movement due to being rubber mounted but overall, it seems tight. I still think the sound is coming from the air intake area so my plan is to remove the air intake and see if the noise goes away. If it is the intake, what are you doing to eliminate the noise?
  2. Jan 19, 2011 at 8:22 AM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    Mine was doing that too. I just took out the plastic piece going into the fender and no noise
  3. Jan 19, 2011 at 10:08 AM
    PeteH
    Thanks,
    I hate to think that the only way to eliminate this rattle is to leave off factory pieces though. Has anyone tried something other than the foam insulating stuff the factory uses?
    I thought about cutting a piece of 3/8 fuel line to length then splitting it down the middle and fitting the hose around the opening.
  4. Jan 19, 2011 at 10:25 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    My intake does that and I used duct tape kinda wraped the end of my filter and it works another use for duct tape
  5. Jan 19, 2011 at 10:39 AM
    07TaCo07
    oregon
    I tried the fuel line around the hole and the rattle still there. So annoying
  6. Jan 19, 2011 at 11:33 AM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    Mine does it too, I think its just the high volume of air the intake is gulping... vibrates everything when you step on it!
  7. Jan 20, 2011 at 5:58 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    I put a strip of weatherstripping around the intake where it meets the fender-problem solved.
  8. Jan 20, 2011 at 6:27 PM
    metric310
    metric310 street taco
    Alejandro
    clinton, ut
    07 prerunner lifted, bumping loud
    3' lift, 10 inch subs, custom TRD sticker, BHLM, leather arm mod, pioneer avic 700 stereo, 5% tint all around
    i bought a urd intake, not it doesn't rub :)
  9. Jan 21, 2011 at 4:01 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I used foam double sided tape. I wraped the foam tape around the intake tube where it contacts the fender.
  10. Jan 21, 2011 at 4:46 AM
    PeteH
    Thanks for the tips.
    I have an appt. scheduled for next tuesday to have this looked at but I think I may be better off fixing it myself and saving the trip to the dealership which is 40 min. away.
    Other than more foam and a softer plastic, are there any differences between the old stlye intake and the new, updated, intake?
    edit:
    For those who did the D.I.Y. fix, what size (width, thickness) weatherstripping did you use?
  11. Jan 21, 2011 at 6:03 AM
    fjm0008
    fjm0008 Well-Known Member
    Jack
    Annapolis
    06 4x4 LB White
    Sirius Starmate and ipod integration w/Pay15 Toy USA Spec, Hardwired Radar Detector and GPS, DRL Mod,Tailgate Anti Theft mod, Hi Lift Jack, CB Radio, Back up sensors, Front 30% tint, Leer 100R Cap, Weathertech, Under hood light and 12V outlet, D Rings, N-FAB Step Bars, Bed Mat, Yakima Bike Rack, OEM Roof Rack
    I fixed mine yesterday. I removed the two bolts for the washer fluid reservoir and used a screwdriver to stuff in some foam packing material all the way around the intake. I tore off some 2 inch long by 1 inch wide pieces and worked around the intake. Started it up this morning in the cold weather and no more grumbling vibrations. It is a very easy fix, don't pay the dealer to do it.
  12. Jan 21, 2011 at 6:09 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I had the TSB done & it still rattled so I did my own fix as described above taking off the washer resi.
    No more rattle & agreed the dealer didn't fix it the first time, certainly would not pay or bring it back for it.
    It drove me crazy in cold temps. Weatherstripping all around=no more rattle.
  13. Jan 21, 2011 at 6:09 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Brother thats not duct tape. We call it ALABAMA CHROME :poking:
  14. Jan 21, 2011 at 2:38 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Fixed mine last weekend. Remove the ducting and wrap some foam tape around the portion that seats in the fender. The foam will dampen any vibrations between the plastic ducting and the metal fender.
  15. Jan 21, 2011 at 6:10 PM
    PeteH
    Fixed it. Got a roll of 1/4 x 3/4 foam tape for $3.99 and re-wrapped the intake where it enters the inner fender. Problem solved!
    Thanks to all for the tips
  16. Oct 3, 2012 at 4:41 PM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    Recently had this same problem on my '07 4Runner. The foam also solved my problem.
  17. Feb 14, 2013 at 1:27 PM
    forealz
    forealz Active Member
    Los Angeles
    07 PreRunner OffRoad TRD 33k
    Any chance any of you could include a picture of the weatherstripping on the intake? (after you did the mod/fix)
    Did you remove the foam first?
  18. Feb 18, 2013 at 9:20 AM
    Bronco76
    Bronco76 New Member
    Michael
    Lexington, SC
    07 PreRunner
    I wrapped the opening in the fender with clear tubing without it stopping the noise. Now to see if foam tape around the inner fender intake piece.
  19. May 6, 2014 at 9:11 AM
    forealz
    Los Angeles
    Did you remove the foam first? :)
  20. Oct 2, 2022 at 7:09 PM
    Jp5385
    Jp5385 Well-Known Member
    2014 TRD Sport V6 4x4
    Sorry to revive such an old thread but if anyone fixed this problem could someone please post a picture of how they fixed the droning noise please? Thanks
