How bad is a 1/2" top plate spacer
Discussion in 'Suspension' started by CJH9980, Dec 10, 2009.
  1. Dec 13, 2009 at 8:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its actually closer to 1* :eek:. Seems if the diff isnt in the exact location, it can exacerbate the vibes. There have been quite a few people who had vibes, only to install the diff drop, and the vibes get worse.
  2. Dec 13, 2009 at 4:02 PM
    CJH9980
    CJH9980 [OP] Well-Known Member
    Clint
    Shreveport, LA/Tucson AZ
    2018 TRD PRO
    Wescott lift Wescott rock sliders Prinsu Cabrack SpartanXcustoms skewp light Demon Hook front recovery point Diamondback SD (just shipped) N2 Designs Remote Start A few meso goodies
    Correct me if I'm wrong, but if you do get the driveline vibes/cv wear, it'll only occur while 4wd is engaged right?
  3. Apr 6, 2020 at 7:56 AM
    NOCOTaco1982
    NOCOTaco1982 Active Member
    Wayne
    2019 Tacoma TRD Off Road Cement
    Premium and tech package, Predator Pro running boards
    I am still wondering about this as I want to buy the 1/2" spacers.... two things.
    1)Are these bad? I figured it would be ok because my understanding is Toyota uses spacers anyway on the Pro model?
    2) does anyone have a link to write up for a "how to" instruction? I haven't done anything like this before but was a mechanic in the Navy....... just don't want to take coils off and then not be able to put it back together? Special tools? etc....
  4. Apr 6, 2020 at 8:53 AM
    CJH9980
    Clint
    2018 TRD PRO
    .5" spacer wont cause you any problems. I cant give you a write up because I used this lift :
    https://westcottdesigns.net/product/fox-trd-pro-lift-kit/
    However if you watch the install video in that link, they show towards the end how to install a top plate, since it's part of the lift. Hope this helps.
    Edit: the pro doesn't come from Toyota with a spacer as you stated in your post. The extra height is provided by the fox coilover
  5. Apr 6, 2020 at 9:36 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    NOCOTaco1982 and CJH9980[OP] like this.
  6. Apr 6, 2020 at 9:40 AM
    CJH9980
    Clint
    2018 TRD PRO
    That's a good visual explanation !
  7. Apr 7, 2020 at 4:59 PM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Did you end up using them on your 2010 setup with the 5100s? I currently have 5100s set on the second notch with close to 1" of lift and was considering installing a set of these instead of adjusting up to the 4th or 5th groove to gain another inch or so.
    CJH9980[QUOTED][OP] likes this.
  8. Apr 7, 2020 at 5:08 PM
    CJH9980
    Clint
    2018 TRD PRO
    Yes, I still have my 2010, my daughter drives it now. It has 5100's set at 0.85, eibach 1.6" springs, and a 0.5" top plate spacer. I had spc UCA's, then switched to TC, then back to the spc because my daughter isn't going to properly maintain the uniball. It's got wheels with -10 offset, and never runs anywhere. That particular lift has served me very well over the 10 year time I've had the truck. I replaced the 5100s a few years back on all four corners, but the other components have remained the same.
    It's about to get a new leaf pack from toyota, they sent me a warranty notice saying the leaf could break and puncture the gas tank, so they are replacing them for free. Pretty good customer service as far as I'm concerned, when dealing with a 10 year old truck! When that happens, I'll put on a new AAL instead of reusing the current one.
    My 2010 is still a damn nice truck, and I'd still be driving it if she hadn't started driving!
    Edit: the 2010 is running 285/75/16 pro comp all terrains. No rub but originally after the lift I had to do some heatgun work on the fender liner
  9. Apr 7, 2020 at 5:15 PM
    CJH9980
    Clint
    2018 TRD PRO
    As far as the lift wearing out the suspension, I replaced both CV axles at about 120k miles. The axles weren't giving me any problems, but I noticed torn boots so I just replaced them. Then at 130ish k miles, one of the front wheel bearings went out, so I replaced them. I dont feel like the lift caused anything to wear prematurely.
  10. Oct 26, 2020 at 7:52 PM
    coryg
    coryg Active Member
    Cory
    19 Cavalry Blue Tacoma SR5 4x4
    Did you have to install longer studs for the spacer?
  11. Oct 26, 2020 at 7:56 PM
    CJH9980
    Clint
    2018 TRD PRO
    I dont think so. I dont remember all the details as it was so long ago, but pretty sure it was the same studs
    Island Cruiser and coryg[QUOTED] like this.
  12. Feb 15, 2022 at 3:45 PM
    chirkin
    chirkin Well-Known Member
    james
    yosemite ca
    1996 tacoma xcab 4x4
    ome 5100 up front ad leaf in rear 31 inch tires
    https://youtu.be/l1tTelhdEiM
    this might help clear up mis information about spacer lifts he cover them at the end but watching the whole video will help understanding as well
    AccuTune Offroad likes this.
  13. Feb 18, 2022 at 6:37 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Using a .4-.5 spacer on top. Youre likely going to need to swap out the 3 top nuts to the shock or flip them upside down. Bc of how the oem nuts are designed. At least on the 3rd gen taco. There is a space in the nut before the threads engage.
  14. Feb 18, 2022 at 6:48 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    Yep I had these on my TRD Pro 4runner and it was no good. I took them off almost immediately, and went with the Westcott Kit to achieve my goal and get some life out of the OEM suspension.
