How best to mount toolbox?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LS1Steve, Oct 29, 2009.
  1. Oct 29, 2009 at 7:57 PM
    LS1Steve
    LS1Steve [OP] Well-Known Member
    I've got a UWS Chest Wedge Box on the way, so it is flush with the top of the bed (doesn't sit on the bed rails).
    I can't see any other way to mount it other than drilling into the bed. I'll have some valuables in it so it has to be secure.
  2. Oct 29, 2009 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats how I mounted my last Flush mount tool box. Drilled 4 holes thru the bed and into the frame. Rock solid.
  3. Oct 29, 2009 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just BE CARFUL to not drill thru anything under the bed. Go under and drill pilot holes first.
  4. Oct 29, 2009 at 8:13 PM
    LS1Steve
    Did you seal it with anything? I'd imagine getting water trapped under the bedliner wouldn't be too good...
    I'm thinkin four 1/2 inch carriage bolts poking up into the bed with a buttload of silicone, then some wingnuts to hold the box to them.
  5. Oct 29, 2009 at 8:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I didnt use any sealant. Not many water issues out here.
  6. Oct 29, 2009 at 8:17 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Yeah, silicone or epoxy them to make them waterproof. But you shouldn't have any water issues like what Chris said.
