How big of a lift with 35" Tires
Discussion in 'Suspension' started by pearldrummerelx, Jul 8, 2010.
  1. Jul 8, 2010 at 8:24 PM
    pearldrummerelx
    pearldrummerelx [OP] Member
    Kevin
    South Florida
    Silver 2010 TRD PreRunner SR5 Double Cab
    I've just bought 20" KMC XD Addicts wrapped in 35" Nitto Terra Grapplers and realized I can't get away with just a 3" body lift. I'm assuming I'll have to do the full 6" lift, cutting the cross member, but I wanted to see if anyone has done this before.
    I have the TSB done in the rear, and a 3" leveling kit in the front. The truck is leveled out right now. I was thinking of doing a 3" body lift as it stands now, but I don't think these tires will fit.
    Also, do I need to change the gearing running this size tire?
    Any advice is appreciated. If you've worked with any particular products and have advice, good or bad, it would be much appreciated.
  2. Jul 9, 2010 at 6:27 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Ideally 6" for 35's but people run 35's on 3" w/ cutting.
  3. Jul 11, 2010 at 12:05 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    you do not need to cut the cross member..you have a prerunner..
  4. Jul 12, 2010 at 7:20 PM
    pearldrummerelx
    Kevin
    South Florida
    which kit can i get so i don't have to cut the cross member? and do i need bigger brakes for the bigger/heavier wheels?
  5. Jul 13, 2010 at 5:55 AM
    sirsaechao
    Tim
    Commifornia
    If you are a prerunner, you wont need to cut the crossmember.
  6. Jul 13, 2010 at 10:07 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    +1
    Cutting the cross member is only for 4x4s. It allows room for the front drive shaft when the front diff is lowered. Prerunner = no front drive shaft and no cutting.
    But you would be better off just getting spindles and running billies on a Prerunner instead of a drop bracket lift.
  7. Jul 13, 2010 at 10:22 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    not all 35's rub horribly, my mud grapplers pretty bad on the sway bar but my trail grapplers only hit at full turn, and also barely touch the body
  8. Jul 13, 2010 at 6:21 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Cut the cross member to fit 35's or cut the fender? I think I would cut the fender. Also to me, fitting big tires with the least amount of lift and the most articulation is awesome.
