How big of a spare tire?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by C17Guy, Sep 11, 2010.
  1. Sep 11, 2010 at 1:50 PM
    C17Guy
    C17Guy [OP] Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    Hey guys,
    Hope TW is doing well. Still on this deployment but figured I could at least get half way ready before I get back.
    Question is this, how big of a spare tire can I fit in the space and rim? Also, which size would I go for to match up with my other wheels/tires?
    Specs are as follows:
    2009 Tacoma access cab(not sure if that matters) 5 lug
    Running 245/75/16 right now.
    I'm assuming the spare is a 15" rim? Would I be able to get semi close to that to make it work if I was to ever blow out?
    Thanks again for the time, internet is a little slow so searching was damn near impossible.
  2. Sep 11, 2010 at 5:18 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I know that they come new with a spare.
  3. Sep 11, 2010 at 6:19 PM
    DevL
    DevL Well-Known Member
    You can fit a 33" tire in the spare spot if you bend the tabs that hold the tire in place of remove the rear exhaust hanger and cut the exhaust so it dumps just past the axle if that is what you are asking.
  4. Sep 12, 2010 at 2:31 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Reckon a 265/75/16 spare would fit the space where a 265/70/16 resides now? Maybe an inch bigger in diameter? I had switched to 75 profile and ended up with a new one in that size as well and got to thinking I hope the sucker will fit the space.
  5. Sep 15, 2010 at 8:53 AM
    vol375
    vol375 New Member
    Albuquerque
    07 4x4 TRD Double Cab
    I have been wondering the same thing. It looks like the 265/75 should fit, but I'd like to know for sure
  6. Sep 15, 2010 at 12:43 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    I have a 285/70/r17 mounted on the steel rim and didn't have to do anything to make it fit.
  7. Sep 15, 2010 at 12:58 PM
    C17Guy
    Dennis
    Thanks for the responses guys! But here's the deal, I started out with a base model, so my stockers were 15s. Tiny tires on there at that. I guess my real question is would I be able to squeeze on a set of tires on that 15, to match the 245/75/16 I have on the truck now? This probably could wait til I get home in November, but I'm bored as shit out here!
  8. Sep 15, 2010 at 1:05 PM
    jdtemple
    Bay Area CA
    I would imagine that all 2nd gens have the same spare tire area. So if a 265 (31.5+/- Diameter) factory spare fits, and in my case a 285 (33+/-" Diameter) fits, you should be good to go.
    Perhaps you could check out the part numbers of the spare tire mounts and compare them between different style trucks.
    Edit to ad : Nice wheels :)
