How big of a tire?
Discussion in '4 Cylinder' started by C17Guy, Mar 16, 2010.
  1. Mar 16, 2010 at 9:02 AM
    C17Guy
    C17Guy [OP] Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    Hey guys,
    I was just curious what you guys thought on tire sizes. Currently running 245/75 on a 16x8 (4.5" backspacing). Also have the readylift 5 lug kit installed. How big of a tire do you guys think I can go?
  2. Mar 16, 2010 at 4:17 PM
    Logan89
    Logan89 Member
    I have 265/65/17 and it rubs quite a bit if i turn the steering wheel all the way.
  3. Mar 16, 2010 at 7:45 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Steven (Stupid hurts.) is running 265/70R16 on his 5 lug. From my research, this is the biggest tire setup I've seen with a Readylift setup.
    from the online tire size calculator
  4. Mar 17, 2010 at 2:38 PM
    C17Guy
    Dennis
    I guess I'm looking for a size that I can jump up to without have to gut the fenders. I'm sure he's rubbing quite a bit. Out of curiosity, what are you running currently?
    I'm also trying to figure out a way of getting at least 2 more inches of life, but I can't find exact prices or which option is the best way. I've heard UCA from total chaos, but then what coilovers do you use? Any recommendations on a way to raise the truck 2"?
  5. Mar 17, 2010 at 2:53 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Total chaos recommends either a sway-a-way or icon coilovers for their UCA kit. The coilovers are specifically made for the 5-lug and you have to cut the factory bump stop off to clear the coilover. I doubt it would be a good idea to run them at the same time as top plate spacers. The TC UCA's plus coilovers are going to run around 1200-1400 bucks for the parts.
  6. Mar 17, 2010 at 3:01 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    I have 31x10.5 on my truck. How high does your truck sit now? Did you take pics before you did your lift?
  7. Mar 17, 2010 at 3:38 PM
    C17Guy
    Dennis
    It's raining outside and I still haven't taken a tape measure to it.... but the only pictures i have are the ones i posted in the 4 cyl.
  8. Mar 17, 2010 at 6:28 PM
    Reaper22
    Reaper22 Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    285R75-16's with spidertrax wheel spacers 2.5 lift no rubbing..
  9. Mar 17, 2010 at 6:33 PM
    C17Guy
    Dennis
    dumb question, but you only use spacers for the front? or both?:confused:
  10. Mar 18, 2010 at 2:56 AM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    Both, to keep it looking right..
  11. Mar 18, 2010 at 11:51 AM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Do you plan on lifting your truck? W/out a lift, stock wheels, you can run 30x9.5/R15.
    With Readylift, I am running 31x10.5 with aftermarket wheels.
  12. Mar 18, 2010 at 12:19 PM
    tmat
    tmat Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    hopefully this helps...I don't have a 5 lugger, but I do have the regular cab prerunner and I'm running 265/75/16 with no rubbing and only bilsteins up front set at 1.75" which I don't think really does anything for tire clearance.
  13. Mar 18, 2010 at 12:20 PM
    tmat
    Treavor
    Cypress, CA
    Just curious...I've seen your tacoma in here quite a bit, but never thought to ask you....did you re-gear? I have the same tacoma as you, but with 265/75r16 tires and I felt a major performance drop with them, but you have the 285s....
  14. Mar 18, 2010 at 12:59 PM
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    No man I did not, but I do have 4:10's and prolly could use a little lower..
  15. Mar 18, 2010 at 1:04 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    If so, I'll take your 4.10s ;)
  16. Mar 18, 2010 at 1:05 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Do plan on installing aftermarket wheels soon? If so, what do you plan on running?
  17. Mar 20, 2010 at 7:57 AM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    I just bought and received 255 75 17 firestone AT I have the stock 265 75 16 on now. I am using the FJ alloys and last night kinda measured them against the truck. I researched it and overall dimensions were only off by .25 all the way around but the tire looks alot bigger than I thought. I wont know until I put them on might need some 5100's. I have no lift currently.
  18. Mar 22, 2010 at 3:57 PM
    silverback
    central CA
    2006 Prerunner SR5
    well took them down to the tire shop to get mounted and I think I am screwed. The tire looks atleast and inch bigger all the way around unlike tireracks estimation. Bummed out If I cant run these today. Save some pennies for the 5100s i guess.
  19. Mar 23, 2010 at 11:28 AM
    silverback
    central CA
    2006 Prerunner SR5
    Wow did I get lucky they fit and no problems with tire rub. I'll post some pics as soon as I figure out how.
