How can I get rid of the mpoisture in my headlights????
Discussion in 'Lighting' started by ETaco23, Apr 6, 2011.
  1. Apr 6, 2011 at 5:14 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I was doing my HIDs yesterday, and it started to sprinkle when I was almost done. So now I have fogged up headlights.:(
    I just put the rubber boots back on, and it seams worse, so now im pissed and dont know what I can do to get rid of it....
  2. Apr 6, 2011 at 5:22 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Use a silica gel packet, like the ones that come in new pairs of shoe, etc. to get the moisture that is in there, out. Put it in the headlight and it will absorb all the moisture/ fog.
    then reseal the lights with a silicone bead all the way around them.
  3. Apr 6, 2011 at 5:26 PM
    06TRDZombieHunter
    06TRDZombieHunter Well-Known Member
    Robert
    Hillsboro, OR
    06 TRD Sport DCLB
    K&N Intake System Port and Polish of TB x2 E3 Diamondfire Sparkplugs 2.5" Leveling kit 32" BFG A/Ts Zombie Response decals Custom painted grill, trim under headlights, scoop, intake and manifold. No more mud flaps, Temp gauge inside intake box, BHLM, extra D-rings in front of bed, No more plastic storage box behind rear seats. More to come.
    Subscribed... Did the BHLM and my passenger side is all foggy.. Living near Portland OR its always wet. I wanna fix it without re-baking the light.
  4. Apr 6, 2011 at 5:27 PM
    jandrews
    '09 FourDubDee TRD OR
    Drill a hole at the bottom. The moisture will just drain out.
  5. Apr 6, 2011 at 5:27 PM
    TexasTacoma37
    :laugh:
  6. Apr 6, 2011 at 5:29 PM
    ETaco23
    Evan
    PNW
    Good idea^ But I have a tiny bit in there. So I want to try and dry them out. Maybe taking out the bulbs and heating them up for awhile?
  7. Apr 6, 2011 at 5:32 PM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    I guess the best way is using a blow dryer and aim it right at the bulb fitting hole. Once moisture is gone, try to reseal anywhere that you'll suspect leaks with silicone.
  8. Apr 6, 2011 at 5:34 PM
    fj6high
    fj6high Well-Known Member
    Howard
    Tarpon Springs
    07' Fjcruiser
    6"Fabtech +OME Heavies and Custo Skyjackers. Way to much to list.
    Pull the bulb out and use a hair dreyer on the lens side...heat it up real good till all the moisture condensation is gone. let it all cool down to ambient temparture before installing bulb back. This will take care of that situation.
  9. Apr 6, 2011 at 5:39 PM
    TexasTacoma37
    If you do that, make sure you point the bulb hole upwards, so the moisture can evaporate upwards and out of the headlight all together.
  10. Apr 6, 2011 at 5:50 PM
    ETaco23
    Evan
    PNW
    Thanks for the advise. I got the truck in the shop with the bulbe out and a light on the front lense. Do you think a hair dryer would work better?
  11. Apr 6, 2011 at 5:55 PM
    TexasTacoma37
    Yeah i think it would make it go quicker
  12. Apr 6, 2011 at 5:59 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Drill hole, drain water, add silica gel, seal hole.
    If all you do is heat the water with the lens sealed, the moisture will just stay inside the lens.
  13. Apr 6, 2011 at 6:00 PM
    TexasTacoma37
    I am not understanding why you guys are saying to drill a hole. when he takes the bulb out of the headlight, that makes a hole for the moisture to evaporate out of.
  14. Apr 6, 2011 at 6:01 PM
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    great idea, never would have thought of that
  15. Apr 6, 2011 at 6:02 PM
    TexasTacoma37
    It works :thumbsup:
    I am way too lazy to sit there and hold a hairdryer when I could just toss a silica gel packet in and go to sleep.
  16. Apr 6, 2011 at 6:03 PM
    jerretxx
    Jerret
    North Carolina
    yeah seriously, why work when the packet was designed to work!!!!
  17. Apr 6, 2011 at 6:06 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    me lazy too! Other more pressing issues to attend to... like surfing tw.
  18. Apr 6, 2011 at 6:50 PM
    jandrews
    Mainly because Jhodge did it and his headlight was about 2/3rds full of water and pissed for like 5 minutes, or so I was told.
    And I was amused.
    Thus, it is now my recommended fix for headlight moisture.
  19. Apr 6, 2011 at 6:52 PM
    jerretxx
    Jerret
    North Carolina
    sounds like a simple fix
  20. Apr 6, 2011 at 7:03 PM
    ETaco23
    Evan
    PNW
    Well since I didnt have much moisture in mine, I was able to just take out the bulbs and use a hair dryer and light to evaporate the moisture. Its almost gone! Im so glad too! :)
