How can I improve my gas mileage??
Discussion in '1st Gen. Tacomas (1995-2004)' started by mendezvinner, Jul 17, 2017.
  1. Jul 18, 2017 at 1:08 PM
    #41
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I could seet that adding up.
  2. Jul 18, 2017 at 1:25 PM
    #42
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    :stayontopic:
    as others have summarized. road conditions and your right foot determine how well mpg works.
    keep your drive-line lubed correctly, fluids changed accordingly, replace worn out items.
  3. Jul 18, 2017 at 6:53 PM
    #43
    Varanic
    Varanic Member
    David
    Austin
    2002 Gold 2.7L RC Prerunner
    Hey, I totally get trying to improve mpg. I get bored on my daily commute so tracking my mpg makes it more interesting. Anyway, I've got basically what should be the most fuel efficient 6 lug Tacoma. It's an 02 reg cab 2.7 prerunner with ~315k miles. I put new general heavy duty leafs on this year which raised the back end 2 inches so I put some old cheap Craigslist fabtech fox 2.0 adjustable coilovers in front that I rebuilt. I also just did the upper & lower ball joints & tie rods. Also I did valve cover gasket, wires & coils last year to pass inspection (cat conv code).
    Anyway, I got a scangauge set up showing current trip mpg, daily mpg, tank mpg & miles to empty. I've also got 265/75r16 street tires overinflated. The ride is hard but I like it. Anyway my mpg is really good I think. (Used to get 17 no matter what speed)
    I average about 24 mpg mixed driving half city half highway. Mostly I just don't drive aggressively. Even hypermiling when I can.
    So on the highway around 55 when traffic allows I get around 30 mpg. At 60-65 I can get around 26-27. At 70 it's closer to 23. At 80 it's 18. In the city timing lights and coasting as much as I can gets me 20-22.
    So anyway for me it's not about saving money or the earth (although both are great) but it's knowing my truck can run at optimum efficiency when I want it to (plus it's something to do).
    I refill the tank when odo hits 400-420 miles & it takes usually 16-17 gallons.
    Ack- also this is without any AC. AC kills my mpg. So it's windows down all the way. On the highway above 55 I'll sometime run the AC and it shaves a couple mpg off.
  4. Jul 19, 2017 at 5:53 AM
    #44
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I thought Reg cabs only had the 15.1 gallon tank? I know Ext/DC has the 18+.
  5. Jul 19, 2017 at 6:12 AM
    #45
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    Mine, 2015 DCSB, has 21 gallons
  6. Jul 19, 2017 at 6:15 AM
    #46
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    welcome to the first Gen section, thank you for posting
  7. Jul 19, 2017 at 7:28 AM
    #47
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    And my wife's Nissan Versa note has 10.8 gallons, but it is also not relevant as well.:crazy:
    InfernoPhil likes this.
  8. Jul 19, 2017 at 8:32 AM
    #48
    Varanic
    Varanic Member
    David
    Austin
  9. Jul 19, 2017 at 11:17 AM
    #49
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    If you don't already have a vacuum gauge installed. That would give you another tool/gimmick to help to monitor driving style.
    cruxofthebisquit likes this.
  10. Jul 19, 2017 at 11:31 AM
    #50
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    that's awesome, I had thought the less front-to-back would have made the tank smaller. but apparently it's top-to-bottom so it's smaller on the 2wd. learn something new every day. :)
  11. Jun 25, 2019 at 6:07 AM
    #51
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Nobody here in 1st gen forum where you asked this question has a 1gr in their taco
    GQ7227 likes this.
  12. Jun 25, 2019 at 8:48 AM
    #52
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    There you go OP.
    Just steal his truck and drive it slow.
    otis24 likes this.
  13. Jun 25, 2019 at 9:21 AM
    #53
    kyleschoen
    kyleschoen Well-Known Member
    Any idea if the gas tanks are interchangeable? Would love an extra 3 gallons in my '00 TRD.
  14. Jun 25, 2019 at 12:11 PM
    #54
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    How many miles do you have on your truck?
  15. Jun 25, 2019 at 12:17 PM
    #55
    APynckel
    APynckel Well-Known Member
    2018 MGM Tacoma TRD OffRoad 4x4 DCSB
    Bakflip MX4 Tonneau Cover XenonDepot ExtremeHID w/ Phillips bulbs
    I've averaged over 27mpg over 250 miles between DFW and Houston. It's all about paying attention to what you're doing. Draft as much as you can, coast instead of braking, watch at least 2 cars ahead of you and anticipate slow downs.
    Remember, the more you brake, the more you'll have to accellerate, and braking LITERALLY converts your kinetic energy (that costs fuel to increase / maintain) into heat. Braking is your worst enemy, as is high speed drag from wind resistance, and rotating mass.
    Other that that, basic maintenance to ensure a free breathing engine and rotating powertrain is about all you can do.
    Hamer95USA and RysiuM like this.
  16. Jun 25, 2019 at 2:11 PM
    #56
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I don't understand why you wouldn't already have it. I do. It says all 6 lugs do. I'd like to have about 25 so I could go 400 miles to a tank also. As is, I fill up at 250
  17. Jun 25, 2019 at 11:11 PM
    #57
    oliverbookboots
    oliverbookboots Well-Known Member
    Juneau, AK
    (Jolene) 2000 2.7L Regular Cab 4WD Manual 177K rebuilt 174K.
  18. Jun 25, 2019 at 11:14 PM
    #58
    oliverbookboots
    Juneau, AK
    We get 20-22 in our 2000 2.7L. Cleaning the intake thoroughly, throttle body, and IAC valve helped alot. As well as replacing the PCV.
  19. Jun 25, 2019 at 11:15 PM
    #59
    oliverbookboots
    Juneau, AK
  20. Jun 26, 2019 at 11:34 AM
    #60
    kyleschoen
    True, but the numbers don't make sense to me — my gas light goes on at about 13 gallons, which would be kinda crazy to have 5 and change in reserve. If I really stretch it I can get about 260 mi range with 14 gallons on a refuel which points to a 15 gal tank. I've never ever put more than 14 and change in the tank. Reading this thread, people seem to be either mid 200 miles on a refuel or mid 300s: https://www.tacomaworld.com/threads/how-many-miles-per-tank.241553/
    So I wonder if some 6 lugs actually have the smaller tank, or maybe my fuel pump/sending unit was replaced with a 15gal version that tells me I'm low on gas way too early?
