How can I mill down high speed steel?
Discussion in 'Off-Topic Discussion' started by soggyBottom, Dec 27, 2020.
  1. Dec 27, 2020 at 2:42 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I found some high speed steel (hss) that is slightly too large for my needs. The rod is 4.2mm and I need approximately 4.15mm.
    It's going into some relatively soft plastic to it's not super critical that it's exactly 4.15mm. how can I mill it down? I don't have a lathe but I do have a drill press and sand paper. Would that even work or am I an idiot for considering it?
    https://www.amazon.com/dp/B082GVX4TM/ref=cm_sw_r_cp_apa_fabc_UUq6FbV56W0QV
    My Name is Rahl likes this.
  2. Dec 27, 2020 at 2:45 PM
    My Name is Rahl
    Why not drill out the plastic to the appropriate size?
  3. Dec 27, 2020 at 2:59 PM
    soggyBottom
    The plastic parts get replaced regularly. I'd prefer to not need to modify the plastic parts every time one gets replaced. I'll do it if there is no other option.
  4. Dec 27, 2020 at 3:07 PM
    My Name is Rahl
    Then you'll have to find a local machine shop.
  5. Dec 27, 2020 at 3:13 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Roll Tide and screw the Suckeyes (and ND)!
    Sorry, back to your regularly scheduled thread.
  6. Dec 27, 2020 at 3:15 PM
    My Name is Rahl
    :fistbump:
    RedWings44[QUOTED] likes this.
  7. Dec 27, 2020 at 5:21 PM
    rtkbowhunter
    rtkbowhunter Well-Known Member
    Southeast PA
    2011 Tacoma Quad Cab SR5
    No access to a lathe, then set it aside spend $4.26 + shipping at McMaster and buy the size you need. You send it to a machine shop to knock .002" it's gonna cost way more than the price of material to size.
    https://www.mcmaster.com/8893K166-88645K51/
    tacotoe, Lawfarin and My Name is Rahl like this.
  8. Dec 27, 2020 at 5:33 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    If the tolerance isn't super critical and the duty is for something personal then I personally would just do as you mentioned, sand paper in a drill press (carefully!) but you're taking about a .05mm tolerance that's pretty exacting...
    Either order to spec or get it machined if it's that specific.
    What is this rod's purpose?
  9. Dec 27, 2020 at 5:37 PM
    rtkbowhunter
    Southeast PA
    For reference .05mm is .002". If you turn it on a lathe you're only moving the cross tool holder .001". Kinda tight tolerance.
    Buy the rod to size from McMaster. Problem solved.
  10. Dec 28, 2020 at 3:46 AM
    soggyBottom
    I already looked and couldn't find the size on MC
  11. Dec 28, 2020 at 3:48 AM
    soggyBottom
    Hinge pins on an rc car
  12. Dec 28, 2020 at 3:54 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Where are you located?
    wilcam47 likes this.
  13. Dec 28, 2020 at 4:11 AM
    Key-Rei
    Key
    Florida
    For the A arms? if that's the case then yeah I wouldn't hesitate to chuck it up in a drill and sand it down till it fit. That said the A arms should be either injected ABS reinforced with fiberglass or similar and therefore relatively strong it probably wouldn't hurt them too much to drill them out either.
  14. Dec 28, 2020 at 4:43 AM
    soggyBottom
    Northern va
    six5crèéd[QUOTED] likes this.
  15. Dec 29, 2020 at 3:01 AM
    rtkbowhunter
    Southeast PA
    The size in the link is .164". That's 4.16mm.
  16. Dec 31, 2020 at 8:03 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Think you could get away with a drill blank? #20 = .161 and #19 = .166. MC or Granger might have that size as a drill blank. If it’s short piece you need, you might be able to cut the shank off from the bit and use that.
    rtkbowhunter likes this.
