How close is too close to the upper control arm?
Discussion in 'Wheels & Tires' started by reg, Nov 6, 2009.
  1. Nov 6, 2009 at 1:16 PM
    reg
    reg [OP] Member
    95 Tacoma
    I have my new wheels and tires and I put one on the front of my 95 tacoma and there is about 1/4 inch of clearance between the tire and the upper ball joint/control arm. Is this clearance the same through all of the suspension travel? I had someone bounce the truck up and down and the gap seems to stay the same.
    I'd like to avoid running spacers if I can, I don't like the wheels sticking out that extra 1.25 inches.
    Let me know what you think.
    Thanks
  2. Nov 6, 2009 at 1:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    1/4" is fine. I have seen less than that. The tire wont move closer. If it does, you have bad bearings. ;)
  3. Nov 6, 2009 at 2:03 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    yeap,the old credit card test works to.
