How critical is torque
Discussion in 'Performance and Tuning' started by KnobleOne, Jun 23, 2012.
  1. Jun 23, 2012 at 4:41 PM
    KnobleOne
    KnobleOne [OP] Member
    Larry
    Upsate New York
    09 DblCab Longbed TRD
    I just completed the 30k oil change in the front and rear diff; and the transfer case. I purchased a torque wrench for the job but I think it failed so I am not sure what torque I applied to all of the drain and fill plugs. One I am sure I over-torqued because the washer became enlongated - I replaced it and applied less torque. Final test I gave the torque wrench was to set it at 20 and apply torque to the wheel lugs - it never released. Seems that all the plugs are in tight, so what is the risk of incorrect torgue on these plugs.
  2. Jun 23, 2012 at 4:44 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    You sure you didn't buy a torque wrench that measure inch lbs instead of ft lbs?
  3. Jun 23, 2012 at 4:48 PM
    cabarbhab
    cabarbhab Well-Known Member
    Andy
    Mary Esther, FL
    2011 DC TRD OR 4x4
    You should be fine, as long as you tightened everything down.
  4. Jun 23, 2012 at 6:12 PM
    KnobleOne
    Larry
    Upsate New York
    It was ft lbs - Gearhead brand purchased at Pep Boys.
  5. Jun 23, 2012 at 6:22 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Overtorque on the drain bolts will strip the aluminum pans/housings/covers.
    Overtorque on a steel pan/housing/cover is not good, but you've got to really crank to do damage.
    Lug nuts are generally around 80ft/lbs. If the wrench is set to 20, it's going to click right away and you'll never feel when you reach 80.
    A click type wrench does not release at the set torque, it simply clicks and you feel it. You CAN continue to crank... the click is just to let you know when you've hit your target.
    In many respects, the old beam style wrenches were more idiot-proof because you could see when you were continuing to go over... if you could see the scale, which was not always possible and the reason for the clicker's invention in the first place.
    Torque is important on all fasteners.
    Some of us have been wrenching for 40 years and have a good sense of feel, and rarely use a torque wrench... I know a lot of guys who can install a set of spark plugs, then a check with a torque wrench will have them within a couple of inch-pounds of spec...
    but we still bring one out when working an unfamiliar system, or high-torque situations where "Oomph" is not good enough to ensure safety.
  6. Jun 23, 2012 at 6:54 PM
    KnobleOne
    Larry
    Upsate New York
  7. Jun 23, 2012 at 6:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    When you surpass the strength of the aluminum casting, or the strength of the bolt. Aluminum will be the first to go in that case, and it will strip when you have over torqued it. Probably around 10-15lbs more than is spec'd.
  8. Jun 23, 2012 at 7:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Actually, On our trucks, the case is more prone to crack before the threads strip........
  9. Jun 23, 2012 at 7:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mine was just a guess, since i have never tested the "stripping point", but that would really suck. Much worse that just stripping the threads. Yikes! Lesson to be learned there, that's for sure!
  10. Jun 23, 2012 at 7:02 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not sure... I don't have a 4x4.
    Easiest way to check is to see if a magnet sticks to the pan/housing, since the only thing you're going to find is steel, iron, or aluminum... maybe magnesium on a motorcycle.
  11. Jun 23, 2012 at 7:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its aluminum.
  12. Jun 23, 2012 at 7:12 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Torque wrench time.
    And set to the proper torque.
    And the proper SIZE torque wrench.
    A wrench that goes from 5 to 60ft/lbs is useful at neither 5-10 nor 50-60 ft/lbs... you want to be in the middle 40-60% of the range for best accuracy (and I know you know this).
    I have 5 torque wrenches including one 1/4" drive for small fasteners on the motorcycle.
  13. Jun 23, 2012 at 7:14 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I can't remember but is it a tapered plug? If so, cracking would be a very big concern!
  14. Jun 23, 2012 at 7:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    cant remember.
  15. Jun 23, 2012 at 7:27 PM
    KnobleOne
    Larry
    Upsate New York
    I guess I am okay, except for the black n blue finger I got from "attempting" to overtorque the transfer case drain plug.
  16. Jun 23, 2012 at 7:35 PM
    KnobleOne
    Larry
    Upsate New York
    Not tapered. Just a straight bolt.
