How did you hard wire your dash cam?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Technical Ted, Jul 26, 2020.
  1. Jul 26, 2020 at 1:37 PM
    Technical Ted
    Technical Ted [OP] Well-Known Member
    Ted
    Western NY - Finger Lakes
    2020 Tacoma Limited Barcelona Red
    Was the A pillar the only thing you have to remove for the whole install for both cameras? Please tell me how you removed it so nothing was damaged.
    Thanks!
    Ted
  2. Jul 26, 2020 at 1:43 PM
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
    I only removed the A pillar. Right behind the airbag SRS plastic cap is a bolt its either a 8 or 10mm, can't recall the size. It is very right, I used strong tape to get it off instead of using a screw driver (plastic cap). I also removed a single bolt on the plastic shroud that holds the knee air bag (behind the weather stripping) to run the power wire to the single fuse tap.
  3. Jul 26, 2020 at 1:46 PM
    Technical Ted
    Ted
    Thanks!
    Ted
  4. Jul 30, 2020 at 7:12 AM
    subhuman
    subhuman New Member
    you can wire the cam power to the review mirror plug by installing a 12v - 5v USB converter (cheap on Amazon). Also, if it has a wired rear camera, run the cable for that through the headliner with a fish tape or stiff wire to the rear window. Did mine in 20 minutes. No tapping into the fuse box and all wires are tucked away in the headliner.
  5. Jul 30, 2020 at 1:32 PM
    968reckless
    968reckless Member
    Al
    i usually tap the windshield wipers for radar installs. they take a lot of power but are not used too often depending on where you live.
  6. Oct 12, 2020 at 11:49 AM
    PilotguyPA28
    PilotguyPA28 Well-Known Member
    Trip
    2020 Metallic Gray Limited
    2020 Limited already has something running off the mirror.
  7. Oct 12, 2020 at 2:43 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Do not do this .. unless u want a trip to the dealer .
  8. Oct 12, 2020 at 4:05 PM
    Toddh808
    Toddh808 New Member
    Todd
    2020 Tacoma Sport
    I have the Viofo A129duo and use this OBD2 power cable from Amazon. It connects directly to your OBD2 port and draws power only and connects directly to your dash cam. There is a switch that allows normal dash cam recording when vehicle is on. Flip the switch and it will power your dash cam in parking mode. I have never left it in parking mode overnight, but instructions says that it will turn off automatically if there is too much battery drain and it hits a certain level. I only use parking mode when doing errands and have never left it on overnight since I park in a secured garage. Works well, no issues. Sorry I'm a newbie to this forum and don't know how to upload pics yet but this is the product description from Amazon.
    OBD2 OBD Power Cable for Dash Camera, Ssontong OBD to Mini USB OBDII Adapter Hardwire Charger Cable 24 Hours Surveillance and Acc Two Mode
    Price: $11.99
  9. Oct 14, 2020 at 11:07 AM
    Assumer
    Assumer Well-Known Member
    Maumelle Arkansas
    2020 TRD White
    GoRhino D1
    What issue will this method cause? I ask because this is what I have been doing for the last 3 months.
  10. Nov 10, 2020 at 9:03 AM
    silver2kws6
    silver2kws6 Active Member
    2019 trd pro black
    c4 bumper & sliders, fj wheels with bfgko 265/75 16
    i agree ive been running mine from the mirror connector for 5 months no issues on my street guardian front and rear camera setup.
  11. Nov 10, 2020 at 11:06 AM
    Josh-L
    Josh-L Well-Known Member
    2021 Silver SR DCSB V6 4x4
    I'm getting ready to install my dash cam. I don't care about parking mode. What's the best fuse to tap into that's power only when ignition is on? I have an SR so no power mirror, I have to hard wire to the fuse box.
  12. Jan 31, 2021 at 8:24 AM
    CoAlpha
    CoAlpha Well-Known Member
    Hi,
    Thanks for the info! Installing this week. I cant tell what fuses did you tap into there behind the cover? Also what amp fuses are you running in top and bottom slots of each fuse tap.
    Thanks again
  13. Jan 31, 2021 at 8:35 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    I have an OBDII plug that powers the camera with a proximity sensor. It turns on if someone is within X number of feet of the sensor. It works well.
    I use the same method in my wife’s Grand Cherokee and my Vette. For my Tacoma I have a splitter to let me run the camera and my ScanGauge.
  14. Jan 31, 2021 at 8:40 AM
    EvenSlow
    EvenSlow Active Member
    Bixby, OK
    2020 MGM TRD Pro
    See page 1
    Post #8
    The VIOFO hardwiring kit doesn’t include two fuses. I think they recommend 2 amp. 5 amps will work also.
  15. Jan 31, 2021 at 9:06 AM
    #35
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    They make a USB adapter that piggybacks off your rear view mirror. Many have done this with zero issues. There's a thread somewhere here that talks about that in pretty good detail.
  16. Jan 31, 2021 at 9:20 AM
    #36
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
  17. Jan 31, 2021 at 9:20 AM
    #37
    Tacowin1013
  18. Jan 31, 2021 at 9:44 AM
    #38
    CoAlpha
    Thanks,
    My bad. Im not that quick today, didn't realize that the images were reversed :)
    And if anyone else is reading this Always hot = Empty Slot, ignition on = USB. If using the VIOFO HK3 ACC Hardwire Kit. Red (BAT) to Empty Slot, Yellow to USB Fuse, Black is the ground.
    Update!
    I tried the Sunroof fuse slot, did not work for always on like some other people did. Used that extra empty slot, yep that works, thats the ticket, its always on. Put the red there! Yellow to USB
    taco_jak likes this.
  19. Jan 31, 2021 at 9:52 AM
    #39
    hockeynut258
    hockeynut258 Well-Known Member
    2019 OR MT
    I did the same to hardwire my camera and no issues. With a strong battery it can go 48+ hours without dropping below the voltage threshold.
    I have the same setup on another car that is now 4 years old and the original battery had a hard time keeping voltage especially when below 40 degrees. Or the camera shuts off when I open the car door.
  20. Jan 31, 2021 at 10:17 AM
    #40
    markram
    markram Well-Known Member
    washington, state of
    2020 TRD OR DCSB 4X4 Cement
