How Different is a 1st gen PreRunner to a Five Lug
Discussion in '5 Lug' started by jcemitte, Jul 20, 2011.
  1. Jul 20, 2011 at 11:03 AM
    jcemitte
    jcemitte [OP] Livin' the taco life
    Jake
    Tulare CA
    04 Taco SR5 5 lugger
    Deck Plate mod, Knock Off Flowmaster,billet grill, alpine HU w/kicker amp and pheonix gold 12" sub stock componets
    lifts and all those other options are pretty limited for our little five luggers. how hard would it be to modify so of those kits to fit?
  2. Jul 20, 2011 at 11:41 AM
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    im going to guess ur talking about A 1gen 5 lug ....... i would say its not possible to do since i havent see anyone do it and im sure by this time some one would have tried.
    If its anything like the 2nd gen trucks the suspension is totally diffrent from 5lug vs 6lugs.
  3. Jul 20, 2011 at 11:43 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    what he said^
    it would probably cost more to do all the fab work to make a 5 lug into a 6 lug than to just buy a 6 lug to start with.
  4. Jul 20, 2011 at 8:33 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    prerunners have struts, longer and bigger spindles, offset upper arm and steering is different as well. as for the 5 lugs we have coils with seperate shocks, centered upper arms and different spindle design. the money you will spend to turn a 5 lug into a prerunner. go long travel. the 6 lug suspension is just built for a bit more abuse while th 5 lugs will break if you push it. if your trtying to get a prerunner save some cash and sell it. too much work and money to convert it. not worth it
