How do I change the stereo in my 2001 tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Frank Cappelletti, Apr 10, 2008.
  1. Apr 10, 2008 at 9:05 AM
    Frank Cappelletti
    Frank Cappelletti [OP] New Member
    Arizona
    2001 prerunner sr5
    Need help with steps for removal of factory stereo & replace with new deck.
  2. Apr 13, 2008 at 7:56 PM
    Zodd
    Zodd New Member
    Canada
    03 Tacoma 4x4
    none yet, shes still new.
    Hey I'm also interested in replacing my taco's tunes, does anyone know the speaker sizes and mounting depth??
    recommendations ?
  3. Apr 13, 2008 at 8:41 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    With my 2001 its not a hard job but it takes a little bit of time and ill give you my best effort in explaining how to remove the factory tuner.
    First turn the truck off lol and unhook you negative battary wire NEED TO DO THIS
    Then you will need to remove very carefully the climate control knobs and the peice behind the knobs that show you what your setting are like hot cold lo hi etc.
    Next you will need to remove the lower peice that holds the ash tray and the 12v plugs. There are 2 clip like things on the side of this peice remove those and remove this peice. Next you should be able to pull the peice that is around your stock radio and that has the 2 ac vents off. Once you get all of that takin off you will see 4 phillps head screws at each corner of your radio and there are 2 plugs that go in the back of the tuner along with the anntena.
    Now please note that when I did mine I did not remove ether one of those dash peices completely off i simply pulled them out of the way now maybe thats an ok way to do it or maybe I got lucky IDK
    When installing your new unit
    1. Buy a wiring harness for it that is made for your truck these make it so easy to put an aftermarket head unit in its unreal.
    2. Be careful with ur dash when you removing it.
    Hope this helps a little bit
    I know its probably not the easiest to understand so if you have any more questions shoot me a pm
  4. Apr 13, 2008 at 11:31 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
