how do i figure gas mileage out with this info?
Discussion in 'General Automotive' started by packfan88, May 8, 2013.
  1. May 8, 2013 at 6:50 AM
    packfan88
    packfan88 [OP] Very Nice !
    Acworth, GA
    Billy Lift, Cooper STT Pro, Westin Step bars, tinted, rain gaurds, EBC rotors hawk pads
    I have been collecting receipts since i first got this Neon and this is where Im at. I tried to do x amount with 91/93 and x amount with 89 but sometimes i forgot and messed it up. somewhere in the middle i switched.
    mileage + gallons
    60140 9.962 gallons
    60281 5.822
    xx,xxx 5.902
    60492 8.605
    60648 3.365
    60907 5.267
    60987 7.500
    61232 2.504
    61292 10.148
    61327 1.513
    61531 7.601
    61699 6.177
    74.366 gallons used
    So now do i factor this once my tank is empty since I started out with a full tank and am not on empty to write down the mileage
    I can wait for the 'ding' low fuel to come on to calculate it, but how much approx fuel is remainign when that happens?
    As of righ tnow it looks like 1559 miles traveled so 1559/74.366=20.96 mpg
    If i get this correct i can remove the last amoutn of gas (6.177) and that will bring me back to a full tank but i keep the mileage.
    1559/68.189 =22.86 mpg
    That assumes i was out of fuel when i filled up last.
    I can make this easy. I will need fuel on the way home. I can either fill up at the ding, fill up when i think im about totally out or fill wup when ever.
    How do i do it?
  2. May 8, 2013 at 9:23 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    just subtract total mileage and divide by total gallons. what you did..take it from there. no foul in starting over :)
    if the data is messed up...you cant just take out chunks of good info and do the same and average them.
  3. May 8, 2013 at 11:39 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I calculate your mileage as 24.2 mpg. The first fill up was not used during the 1559 miles.
  4. May 8, 2013 at 12:19 PM
    packfan88
    Acworth, GA
    So if i started with a full tank do i drive til i need another full tank or til an empty tank?
  5. May 8, 2013 at 12:21 PM
    packfan88
    Acworth, GA
    data isnt messed up. i just didnt write down the mileage on the one receipt (#3). it can be calculated into the grand total tho right?
    As far as which octane, some gas station put what you bough ton the receipt and some dont. Since i buy some in NJ and some in NY i cant tell if $$3.99 was NJ cost for super or NY cost for regular. Id have to start over with that figure and write it on the back.
  6. May 8, 2013 at 12:41 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Use your tripometer, set to zero when you fill up. How many gallons your tank holds divided by how many miles you have went.
  7. May 8, 2013 at 6:40 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Doesn't matter what the tank holds... It is how many miles you drive from the last fill up to the next fill up... Don't add any gas between the two.
    1) Top your tank (fill up)
    2) Zero your trip odometer
    3) Drive until you are ready to fill up again (for me it is close to 300 miles).
    4) Record how many gallons went into your tank.
    5) Look at your trip odometer and write down the miles you drove, then zero it again for the next tank.
    6) Divide the miles driven by how many gallons you added.
    Example: 313.6 miles divided by 17.5 gallons = 17.92 MPG (miles per gallon)
    The 2005+ Tacomas all have 21 gallon tanks, and the low fuel light will come on after 17 gallons are used (4 gallons still remaining). The needle will point to E when you are down 18 gallons (3 gallons still in tank). You shouldn't wait until then to add gas, but you should know this in an emergency situation.
  8. May 9, 2013 at 5:40 AM
    packfan88
    Acworth, GA
    Its a long story but I dont want to reset the trip odometer. This Neon only has one and the standard odometer. I was also hoping to do this over the span of 10 tanks of gas or somethign like that so its more of an average. Sometimes I drive highway but most of its NYC traffic. 1/4 tank at highway will skew it up and read too high.
  9. May 9, 2013 at 5:48 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    You got a smartphone?
    I had an iPhone and downloaded an app called "Road Trip". Now I got an Android and have an app called "FuelLog". Just plug in data from the gas receipt everytime you fill up and it continually tracks your running MPG and can make some neat graphs and estimated yearly values. It takes under a minute to enter and I just do it real quick before I pull away from the pump everytime.
  10. May 9, 2013 at 9:33 AM
    packfan88
    Acworth, GA
    Gonna start over using Gas Cubby app.
  11. May 10, 2013 at 5:46 PM
    donson6
    donson6 Well-Known Member
    2002 4x4
    lots
    Why do you care so much about your gas mileage on a Dodge neon? I think you should be happy the damn thing is still running, and WHY would you ever put anything in the gas tank, other than regular gas??
  12. May 10, 2013 at 6:02 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You don't have to empty the tank, but to calculate, you always need to completely fill the tank.
    If you ever do a partial, then take the mileage from the last full tank to the next time you fill it, and add the total of both fuel-ups.
    But you have to be consistent....
    There's your overall on the right... 24.2... but look at the tank to tank. Because of what I assume are partial fills, you are showing everything from 6 to 100mpg.
    Compare that to my attached spreadsheet that I used to track my '03 Tundra.
  13. May 10, 2013 at 10:46 PM
    David K
    You don't need a trip odometer, just write down the odometer miles at each fill up, and subtract the smaller number from the larger...
    Example: Odometer reads 47,516 miles when you fill the tank... and 47,815 miles when you fill it again... That is 299 miles between the two fill ups. The second fill up you added 12.7 gallons... 299 divided by 12.7 = 23.5 MPG (miles per gallon)
  14. May 10, 2013 at 10:51 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Miles driven divided by amount of fuel consumed. Very simple.
    Get a Fuelly account if you need someone to do it for you.
