how do I get into 4 wheel drive
Discussion in '1st Gen. Tacomas (1995-2004)' started by Carl Messina, Feb 25, 2008.
  1. Feb 25, 2008 at 8:49 AM
    Carl Messina
    Carl Messina [OP] New Member
    2004 4X4 tacoma
    I just bought a 2004 tacoma 4X4 - I used to have a Nissan Frontier - obviously the way to get the truck into 4 wheel drive is very different. Can anyone give me a brief description of how to get the truck into 4 wheel drive.
    Thanks.
  2. Feb 25, 2008 at 10:24 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    In 04 there were two different 4wd systems.
    On the 4cyl trucks there is a second stick next to your main gearshift. Pull straight back untill it stops for 4HI. For 4LO stop the truck, put the trans in Neutral. (Clutch in if a manual) push lever all the way to the right and then all the way forward for 4LO.
    The v6 engine trucks have a button on the transfer case lever for 4HI. Press the button to engage 4HI and press again to dis-engage. 4LO should be the same regardless of engine size, Neutral, (clutch in) down, right, then up, but it might just be right, then up. I am not 100% sure on that.
  3. Feb 27, 2008 at 8:51 AM
    DefyInertia
    DefyInertia Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    That sounds a lot more complicatd than for my 5speed 2001.
    I just push the button for 4H or move the 4x4 shifter all the way forward for 4L.
    The owner's manual describes how and when to make your shifts and provides other general reccomendations as well.
  4. Feb 27, 2008 at 4:43 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    The Automatics work the same way, and you might also find some instructions on the back of the sun-visor( I can`t remember for sure).
