how do i make my ifs flex...?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tt01, Oct 19, 2009.
  1. Oct 19, 2009 at 8:35 PM
    tt01
    tt01 [OP] Active Member
    Canal Fulton Ohio
    01 tacoma 6" suspension lift
    35" tires, 15" wheels 6" suspension lift (fabtech),
    im new to this whole forums thing but was wondering if anyone could give me some info on my 01 tacoma it has the ifs front suspension i have a 6" lift on it and it doesnt flex out at all really i would like to keep the ifs and not convert to the straight frontend anyone got any ideas...
  2. Oct 19, 2009 at 8:36 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    take your sway bar off
    but be carefull it will handle WAY diffrently
  3. Oct 19, 2009 at 8:45 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    it does handle differently. It didn't give me as much of an independent front end as I wanted but I'm also at stock height so that'll probably make a difference.
  4. Oct 20, 2009 at 7:38 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Cut it all off and put a solid axle in.
    (sorry, had to say it) ;)
  5. Oct 20, 2009 at 7:52 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Long travel the rear suspension. I've seen some incredibly capable rigs that were long travel in the rear and not very flexy in the front. It's a decent compromise between keeping the IFS and keeping all 4 tires on the ground when crawling.
  6. Oct 20, 2009 at 1:04 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
  7. Oct 20, 2009 at 4:04 PM
    Janster
    Jandy
    Lancaster, PA
    Do you have any idea how much it would cost to build a setup (front suspension) like that?
    Cheaper to do a solid axle swap!! ;)
  8. Oct 20, 2009 at 4:15 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    do you still run your sway bar?? if not have you completely flexed yours out since you put on the fox's...?? i'm pretty impressed with mine to be what it is..
  9. Oct 20, 2009 at 4:18 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Hell yea man!!! SAS would be the way to go!! If only I had the money :eek:
  10. Oct 20, 2009 at 5:16 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    What should one expect for added travel and difference in handling when removing the Sway Bar?
    Obviously the Travel depends on the type of Suspension set up, but any general thoughts? Right now im limited by my stock bump stop brackets until I get some Limit straps but Id like to know what more I can gain.
  11. Oct 20, 2009 at 5:47 PM
    Fire931
    VA
    00 4Runner
    all depends on the setup your running.. its not that difficult to unbolt.. just take it off for a few days and try it out.. if you dont like it you can always bolt it back on.
    silver... what you order now???
  12. Oct 20, 2009 at 5:50 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    travel gain is like 2 more inches with a stock 98 4wd
  13. Oct 20, 2009 at 5:53 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Just removing the sway bar is the easiest way to get some more flex out of IFS. SAS would be nice, but lots of work and money to do. Heres the flex out of mine with the sway bar removed:
  14. Oct 20, 2009 at 6:19 PM
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    I didn't notice much difference after removing my swaybay, onroad or offroad, the only thing i noticed was it handles bumps in the road much better b/c it doesn't absorb it w/ both tires just one.
  15. Oct 20, 2009 at 8:18 PM
    Janster
    Jandy
    Lancaster, PA
    Although removing the sway bar might not be noticable under normal circumstances.... the critical part, is if/when you ever have to make a panic manuever. It could make the difference between staying on 4 wheels and rolling over.
    I know the 1st gen trucks have quick disconnects for the sway bars. I had a set on my 96.
    Not sure if anyone has them for the 2nd gens yet...
  16. Oct 20, 2009 at 11:00 PM
    Janster
    Jandy
    Lancaster, PA
