How do i paint rims black?!?!
Discussion in 'Southern California' started by obsurfer1990, Nov 13, 2008.
  1. Nov 13, 2008 at 3:20 PM
    obsurfer1990
    obsurfer1990 [OP] Well-Known Member
    san diego
    06 prerunner
    do i need to get my rims powder coated? and how much does that usually run?
  2. Nov 13, 2008 at 3:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can get them powdercoated, but it aint too cheap i dont think. alot of people have painted their rims....and they look great and are easy to do. you gotta prep the wheels real good(clean, sand, clean again) and you need to use a wheel primer and a wheel paint for the finish to last longer. oh yeah.......its alot cheaper than powdercoating too.
  3. Nov 13, 2008 at 3:43 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Powercoating is an option. It tends to be a bit more durable than paint- but if it gets damaged it needs to be completely re-done to fix it. More expensive than paint but less work for you.
    Paint can be repaired easily but needs to be repaired more often. It is less expensive than powdercoat...but takes more time to do.
    As far as painting your rims- Take them off-Clean them very well. Sand with a fine grit (between 600 and 1200) until the whole surface where you want paint to stick is roughed up. (if you miss any spots you can get paint beads and bubbles). Wipe with alcohol or another solvent to get all the dust...Tape the tire (if you are worried about it) and then- Shoot!!
    Spray 1-2 coats of primer-I used a sandable filler/primer to fill a couple of divits in the lip of the rim and some scratches. Follow the can directions-Allow at least enuf time between coats for it to be dry to the touch (clean hands). Sand and re-prime if needed.
    Paint (I used 3 coats per rim) using can directions and allowing for proper drying. Re-install and bask in the glory of all the admiring stares you get while driving around...
    Check out my gallery if you want to see pics of what is possible-Good luck!
  4. Nov 13, 2008 at 4:21 PM
    BGreene
    BGreene Rookie Member
    Brandon
    Sharpsburg, Georgia
    08 PreRunner SR5 DC- Black
    Blacked Out Emblems, Blacked out grille, 20% Tint-over factory, Paint matched rear bumper, 3" Suspension Lift, Custom "TRD Black" Decals, BHLM, Seat belt chime mod. Mods to come: Bull bar, step bars, scooped hood, OEM skid plate, tinted tails
    I also had many questions when I went to paint my wheels black.
    Many people will tell you- Prep is everything! - That's the truth! There are also a couple instructional videos on Youtube that are good.
    Check out my gallery for pics of my wheels I painted black.
