How Do I Remove Newsprint Stain From Plastic?
Discussion in 'Detailing' started by LeftyTom, Jun 5, 2011.
  1. Jun 5, 2011 at 11:44 AM
    LeftyTom
    LeftyTom [OP] Well-Known Member
    Yadkinville NC
    2011 Tacoma AccessCab, 2WD, 5spd, SR5
    I was using newspaper to clean my windows. Some of the moist newspaper rubbed against my center console, and left a black stain. :eek:
    Any tips on how I can get the black stain off the gray plastic?
  2. Jun 5, 2011 at 11:51 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    lots of elbow grease unfortunately
  3. Jun 5, 2011 at 12:40 PM
    LeftyTom
    Yadkinville NC
    I got it off using rubbing alcohol (make that RUBBING! alcohol). I used the soft side of a ScotchBrite pad for the tough spots. Of course, the side effect of alcohol is that is dries out the plastic, so I promptly followed up with a wipe down with a paper towel damp with water. A few minutes later, with the plastic dry, I followed up with McGuiars detail wipes.
  4. Jun 5, 2011 at 12:42 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    smart man!
  5. Jun 5, 2011 at 12:47 PM
    Hiatt1991
    Hiatt
    Glad it worked out!
  6. Jun 5, 2011 at 2:37 PM
    LeftyTom
    Yadkinville NC
    Another possible remedy is a baking soda and water paste. The advantage to trying this method is you can use an old tooth brush (or a denture brush, which has a larger head) to scrub the stained area(s).
