How do i remove this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sambojee, Apr 19, 2011.
  1. Apr 19, 2011 at 7:05 PM
    sambojee
    sambojee [OP] Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    Like an idiot (before i found tw) i super glued my light switches for my light bar and fog lights to my panel on the left side, is there anyway to remove this without ruining the plastic? im not gunna be removing then anytime soon but i was just woundering
  2. Apr 19, 2011 at 7:09 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    super glue is tought stuff. Some solvents will soften it up (mineral spirits, paint thiner, etc) but will probalby bleed the color of panel and make it very soft.
  3. Apr 19, 2011 at 7:15 PM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    yeah thats true. well im gunna not think about it till i sell it. i could of made it look so much cleaner but i guess what i have now is not that bad
  4. Apr 19, 2011 at 7:16 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    What Plastic, any pictures? If you just super glued on the plastic blanks where switches could go, like mentioned above you can just replace the blanks.
  5. Apr 19, 2011 at 7:36 PM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    i took the blanks out and put the wires through there and the switch its self goes over the hole
  6. Apr 20, 2011 at 6:01 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd use a fine tooth hobby saw blade between the two pulling towards the switch while sawing to hopefully not damage the plastic then once removed use nail polish remover sparingly (or your finger nail, maybe) on the glue to remove the residue.
  7. Apr 20, 2011 at 6:13 PM
    monkey wrench
    monkey wrench Well-Known Member
    sean
    somerset, ca
    stock 4x4
    new stereo, rear leaf tsb, front 5100s @ .75. weather tecs and wet okoles.
    acetone will dissolve crazy glue. it might discolor the dash plastic too.
  8. Apr 20, 2011 at 6:19 PM
    rcfreak201
    rcfreak201 Well-Known Member
    once you do figure out how to remove the glue or get a new blank just do this
    i cut out a little square just enough to have the switch squeeze through and ran the wires behind it so its super clean, as you can see i screwed up on the first try(orange switch) but i think it looks clean:cool:
    as far as taking off the glue i have no idea:confused: lol
  9. Apr 24, 2011 at 11:38 AM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    yea im for sure doing it like this if i ever get any more lights. i just wish i found tw earlier before i did this haha
