How do I stop the beeps when I lock or unlock my Taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Feb 13, 2009.
  1. Apr 8, 2022 at 4:53 PM
    #161
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Definitely aftermarket.
    Norton likes this.
  2. Apr 8, 2022 at 4:55 PM
    #162
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    You have two choices: Follow a procedure that's documented in here somewhere or in the manual and perform a multi-step procedure (38 total) that involves your remote, turning the key off and on 50 times, stepping on the brake pedal with the passenger door open, idle in N for 30 minutes and setting the radio to the PBS channel. (AM only) with the dome lamp on and lock/unlock the truck 40 times within 40 seconds sitting in the passenger seat with the seat belt on. Or seal it off with a glob of the that expanding yellow foam that if you get it on your hands it never comes off. I can't stand the beeps. Like someone else said, my boss listens for it when I take off early and threatens to dock my pay $2 the next morning when I come in. (he never does) :thumbsup:
    -OR-
    Unplug the little beep gizmo under the hood.
    Key-Rei likes this.
  3. Apr 8, 2022 at 8:20 PM
    #163
    blur
    blur Well-Known Member
    That’s not true. There is a fairly easy “secrete hand shake” you need to do. I’ll have to search for the thread but it wasn’t difficult to execute once you know what to do.
  4. Apr 8, 2022 at 8:23 PM
    #164
    blur
  5. Apr 8, 2022 at 8:48 PM
    #165
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Legend has it jmedd99 is still on his boss’ shit list for leaving work early:thumbsup:
  6. Apr 10, 2022 at 7:00 PM
    #166
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    It's been about a decade since this post so I figured I might as well chime in again - I never touched the earplug that I stuck in the speaker and to this day the beeps are still muffled just right.
    See ya guys in 2032.
  7. Apr 11, 2022 at 11:23 AM
    #167
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    Whoo HOO!
    Beeps off!
    Last week, I was at SpralMart - went to unlock my truck and the moment before I hit the button, some other Toyota owner unlocked theirs with the same beeps - the beeps already annoyed me and that was the final annoyance - luckily this thread was front and center - it took me a few tries, a few separate times, probably b/c I wasn't waiting long enough - but it's done now and I am much happier!
    Thanks TacoWorld and all yallz here that posted the process/tips/tricks for doing this.
