how do i take this off? HELP FAST PLEASE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDBandit, Jul 25, 2011.
  1. Jul 25, 2011 at 9:54 AM
    TRDBandit
    TRDBandit [OP] TACOMANATOR
    Justin
    CRAWLORADO
    07 Dbl Cab TRD O.R. Dark Blue
    Afe Stage 2 CAI Tinted windows Many to come
    Do I just hammer this off? Is there bolts in the back? Got the caliper off. Or do I take off the ball joints first? Im Replacing my bent steering knuckle. I already got the big nut off in the middle
  2. Jul 25, 2011 at 9:58 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    you can run 2 bolts in the holes and those will force the rotor off the hub... not sure the size.
  3. Jul 25, 2011 at 9:59 AM
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    Those 2 bolt holes take a bolt that you screw in and it pushes the roter off
  4. Jul 25, 2011 at 9:59 AM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
    see the two little threaded holes?
    you should be able to put a bolt in them and screw it down to push the disc off
    sorry, don't remember the size. 10mm I think
    or a few whacks with a rubber mallet
  5. Jul 25, 2011 at 9:59 AM
    TRDBandit
    Justin
    CRAWLORADO
    So I keep tightning the bolts until it pushes it out?
  6. Jul 25, 2011 at 10:00 AM
    JasonJump
    Yukon Oklahoma
    yes
  7. Jul 25, 2011 at 10:01 AM
    bobfm10350
    bobfm10350 Well-Known Member
    Deric
    Austin Texas
    06 PreRunner TRD Off Road
    Access Limited Tonneau, Hawk LTS Brake Pads, SP Performance Slotted Rotors, Goodrich G-Stop Brake Lines, Thule Roof Rack, Bilstein 5100s Front and Rear, Eibach Coil Springs, Cabela's Floor Mats, 265-75-16 Duratracs, Fog Light Anytime Mod, D-Rings Mod, USA Spec PA15 TOY Ipod Adapter, Gorilla Lock Nuts, K&N Drop-In Air Filter, Wet Okole Seat Covers Front & Rear, Toytec 1.5" AAL, Viper 5901 Car Alarm
    I'm assuming your trying to get the rotor off, but if you can find a screw to fit into any of those two holes on the same ring as the lug nuts then just thread them in. It should push the rotor off.
    *Way too late on that one!
  8. Jul 25, 2011 at 10:02 AM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    Have you tried hitting them with a mallet, that usually does it. I only had to do the bolt holes when they were old and rusty.
  9. Jul 25, 2011 at 10:02 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    or rotor cracks :D
    BTW those holes need M8 bolt
  10. Jul 25, 2011 at 10:03 AM
    DonnoD
    DonnoD Well-Known Member
    don
    las vegas
    07 dc 4x4 v6
    just hit the rotor with a hammer,do not hit it on the face of it where the pads make contact, hit it on hub part and make sure not to hit the studs.
  11. Jul 25, 2011 at 10:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    I hit the hub, not the rotor. :p
  12. Jul 25, 2011 at 10:05 AM
    BlueT
    NorthEast
    I was talkign about those bolts. If you thread them and keep turning to push rotor out either rotor gets free or it cracks (ask me how I know this :cool: )
  13. Jul 25, 2011 at 10:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    Ouch. At least it came off.
  14. Jul 25, 2011 at 10:09 AM
    TRDBandit
    Justin
    CRAWLORADO
    Thanks. Got that off. What about this? There is 4 bolts in the back. Got those loose but it still wont come off.
  15. Jul 25, 2011 at 10:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    They won't come out until/unless you pull the wheel bearing
  16. Jul 25, 2011 at 10:11 AM
    TRDBandit
    Justin
    CRAWLORADO
    Do they need to come out to replace the spindle?
  17. Jul 25, 2011 at 10:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    Nope, they need to be loose like you have them (completely unthreaded).
  18. Jul 25, 2011 at 10:12 AM
    YFZ_TRD
    YFZ_TRD 4Runner Pilot
    Lee
    Beaverton, OR
    2014 4Runner SR5
    Rubber mallet or a dead blow hammer will be your friend for the rotor and the hub assembly you just removed the bolts from.
  19. Jul 25, 2011 at 10:12 AM
    BlueT
    NorthEast
    It did, and now I have stand for metal work (welding ):D
    I have ogre hands :eek:
  20. Jul 25, 2011 at 10:13 AM
    98tacoma27
    Ben
    Not Beech Creek
    :laughing:
