How do I wire my 3rd brake light (camper)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Jan 31, 2019.
  1. Jan 31, 2019 at 11:55 AM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
  2. Jan 31, 2019 at 12:33 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    Cutter_[OP] and Taco critter like this.
  3. Jan 31, 2019 at 12:44 PM
    Cutter_
    Sweet, I know how to feed the 3rd light wire, but how do I tap into the left brake light?
  4. Jan 31, 2019 at 12:48 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    As far as connecting to your BRAKE light, on second thought, you might want to go with a prefabricated wiring harness in lieu of the above.
    Its never good to wire into existing tailights as it breeds future trouble!
    I have this Hopkins harness on my 2003 Tacoma and it works flawlessly for connecting trailer lights with no splicing.
    You can then get an adapter connector to connect your two wire light to this.
    https://www.amazon.com/Hopkins-4331...&qid=1548967260&sr=8-1&keywords=hopkins+43315
  5. Jan 31, 2019 at 12:54 PM
    Cutter_
    I'm not connecting to a trailer, I want to wire my camper shell brake light to my truck itself
  6. Jan 31, 2019 at 12:56 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    You would cannibalize this harness to adapt it to the brake light...
    This is a suggestion to avoid splicing directly into your tail light.
    You would only use 2 or 3 wires of the 4 wire plug, which has several feet of extension.
    So the plug would rest where your camper top sits on the truck bed.
    Connecting and disconnecting just the 4 wire plug itself... Got it?
    Of course if you want to splice into your brakes you can still do that.
    You can get directions for doing that on this forum or anywhere on the internet.
  7. Jan 31, 2019 at 1:13 PM
    Cutter_
    I see what you mean, and I wouldn't want to splice.
  8. Jan 31, 2019 at 1:20 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    Cutter_[OP] likes this.
  9. Jan 31, 2019 at 2:25 PM
    Cutter_
  10. Jan 31, 2019 at 2:41 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    No, you understand it rightly.
    If you ever wanted to have a running light as well on your camper top that would be the 3rd wire.
  11. Jan 31, 2019 at 2:48 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    They make 2-wire trailer connectors .That's what I use on my softopper. Picked it up at the corner auto parts store. Easy peasy. m_74215_primary.jpg
    Trowbocop and Cutter_[OP] like this.
  12. Jan 31, 2019 at 3:49 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    The question was about how to and whether to splice the connector into the the tail light...
  13. Jan 31, 2019 at 5:18 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    The point was I saw a lot of parts being shown, I wanted to show a simple part that I used.
    But ok fine, I'll opine on part A of the question since you asked. :thumbsup: I spliced mine into the left tail. I'm comfortable using a soldering iron and shrink-tubing, so that's what I used. Simple, clean, effective. There are many ways to skin that cat though - crimp-unions with electric tape are relatively robust when done right. The euro-style 3 port wire terminals are darn near idiot-proof, but they're overkill for such small gauge wires here. Just don't use T-taps . Those can wear and break over time.
    After I spliced I routed up to the left cubby, which is where I store the trailer connector part I talked about earlier. Plug it in when the softopper is up, unplug when it's folded down. Visible wires are a major peeve of mine. I don't like seeing wires on my Christmas tree, I don't like seeing them on my house audio/entertainment system, and I dang sure hate seeing them on my truck. Keeping the plug in the cubby keeps it neatly tucked out of sight.
    As far as the 3rd brake goes, I used a cheap 36" red led bar. Its plenty bright and has such a low power draw that the incandescent bulb that it's parasiting from doesn't feel it.
    Again, cheap, simple, easy peasy.
