How do quickfists mount to bed rails?
Discussion in '3rd Gen. Tacomas (2016+)' started by TacoManTaco, Dec 25, 2018.
  1. Dec 25, 2018 at 8:31 AM
    TacoManTaco
    TacoManTaco [OP] Well-Known Member
    Picked up a pack of quickfists to mount my shovel to the bed rails, not sure how it works. What parts do I need? Don't need anything fancy, just need to get the job done securely.
  2. Dec 25, 2018 at 8:32 AM
    SpeySquatch
    2016 TRD OR DCSB
    C4Fab LoPro, BAMF Sliders, Adj. Ext ADS, 4.88's, OVTune
    Just get a bolt to fasten to them and a washer on the bolt to rest in the bed channel. As you tight the washer pulls to the inside edges of the rail
  3. Dec 25, 2018 at 8:32 AM
    Matmo215
    Matmo215 Baylor ΣΑΕ
    Matthew
    Waco, TX
    2015 Sport DCSB
  4. Dec 25, 2018 at 8:36 AM
    TacoManTaco
    Thanks, what size bolt/washers do I need to buy?
  5. Dec 25, 2018 at 8:37 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Get T Nuts that slide into the rail. 59083C86-A2F0-4EB4-B3D0-341ED0767F1A.jpg
  6. Dec 25, 2018 at 8:39 AM
    tacomarin
    tacomarin ig: @the_chubby_unicorn_trd
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack Tradesman Truck Shell LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Custom Bed Platform/Drawers 285/75r17 BFG KO2 X-Bull Recovery Boards Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    I think they are 3/8-16 T-nuts but if you type Tacoma bedrail t-nuts into Amazon you will find them.
    You will have to drill out the quick fists for the bolt. I think I used a 3/4” long bolt.
  7. Dec 25, 2018 at 8:58 AM
    TacoManTaco
  8. Dec 25, 2018 at 9:01 AM
    TacoManTaco
    Where did you buy those brackets?
  9. Dec 25, 2018 at 9:15 AM
    Enfield1
    Enfield1 Well-Known Member
    Brad
    Bryan, Tx
    '18 White DCSB OR 4wd auto
    The company that makes those dash mounts, has some really nice T-nuts. Can't recall the name at the moment.
  10. Dec 25, 2018 at 9:18 AM
    SpeySquatch
    2016 TRD OR DCSB
    No idea. Measure your channel for the washer, bring your clamps to the hardware store/HD
  11. Dec 25, 2018 at 9:20 AM
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    A #10 screw won’t thread into a 3/8” nut. You will need to get a 3/8-16 screw of the appropriate length and drill out your quickfist to fit it.
  12. Dec 25, 2018 at 9:42 AM
    TacoManTaco
    OK, now I'm confused. The packaging on quickfist says to use a #10 screw. But all the T-slot nuts I see on Amazon are 3/8"-16. I don't know how to use a drill. Are there t-slot nuts that will fit a #10 screw, or if not, is there an easy solution? Just need it to be secured when driving at 80mph.
  13. Dec 25, 2018 at 9:45 AM
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    There are not T slot nuts for the bed rails with a #10. #10 is a puny bolt. Everyone drills them out. It is easy and fast.
    Here is info about drilling them out: https://www.quickfist.com/index.php/quick-fist-installation-instructions
  14. Dec 25, 2018 at 10:45 AM
    TacoManTaco
    Thanks -
    Do I have to get the T-slots? Or can I just go to home depot and get a washer that will fit in the bed rails, and a nut that will take a #10 screw? Or will that not be secure?
  15. Dec 25, 2018 at 10:50 AM
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    That might work but wouldn’t be as stout. You’d also have to figure out how to tighten it without the nut spinning.
  16. Dec 25, 2018 at 11:37 AM
    Captqc
    Tigard, OR
    Just bought some steel stock from the hardware store and cut to length. I added rubber bottle stoppers at the bottom. Make sure you prime and paint the straps with good paint or they will rust (unless you find stainless steel stock).
  17. Dec 25, 2018 at 11:40 AM
    Dishsoap
    Dishsoap Well-Known Member
    White Mountains, NH
    2016 SR5 DCSB V6
  18. Dec 25, 2018 at 1:33 PM
    McKBrew
    McKBrew Active Member
    Jess
    North Idaho
    2018 TRD OFFROAD DCSB Quicksand
  19. Dec 25, 2018 at 3:23 PM
    DRansom
    DRansom Well-Known Member
    Newark, CA
    2018 Silver Tacoma TRD Sport 4 X 2
  20. Dec 25, 2018 at 4:19 PM
    Dishsoap
    White Mountains, NH
    2016 SR5 DCSB V6
    The ones I used we're the smallest my local hardware store had. I'll have to check Lowe's or home Depot for some I don't have to grind down
