how do you change belt?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheTacoManChach, May 10, 2010.
  1. May 17, 2012 at 9:04 AM
    oldstick
    oldstick Medicare Member
    GA
    Rule of thumb I have always heard is to check regularly and as soon as you see any bit of the ribs (that ride in the grooves) missing, then it's time. You usually see some small cracks develop in the ribs as it ages and dries and they say some amount of cracks are Ok. But if I see cracks all the way around I figure the next step is chunks falling off so I go ahead then as well.
    I usually like to replace anyway, regardless of condition around 100K, if not before. I usually just tuck the old one under the seat for an emergency spare.
  2. May 17, 2012 at 9:14 AM
    oldstick
    GA
    One time my Dad, a retired minister, who was probably 65+ at the time changed the serpentine on his car. Later he was at the Ford dealer. He was friends with the owner and they said "Who changed the belt on your car?" Owner was only half joking when he offered my Dad a job.
    Said he had more than one tech who couldn't manage to change the belts on that particular car. (I think it may have been a Taurus or Sable but not sure.)
  3. Oct 18, 2012 at 9:11 PM
    evolution6972
    evolution6972 Well-Known Member
    Looked this up and with the pictures had it done in 15 minutes soo glad y'all are on here
    rickydood likes this.
  4. Nov 25, 2012 at 5:16 AM
    BreezyTaco
    BreezyTaco Well-Known Member
    Corpus Christi, TX
    Pioneer Indash GPS, JL Audio Speakers, FM Alarm, Euro Tail lights, Blue Dash Lights, Trailor Hitch, Painted Fiberglass A.R.E. Tonneau Cover
    Thinking about doing this, but I am by far the mechanic, super nervous
  5. Nov 25, 2012 at 6:25 AM
    evolution6972
    Yea breezy I thought the same way but if if you have a smart phone or a computer close by use the pictures they have posted. Drop the bottum pan four screws and then a screw driver and a ratchet and then it's all routing the belt not hard the pictures helped me. It can only go on one way so if you got to much slack or two little refer to picture.
  6. Jan 21, 2013 at 9:22 AM
    geogecko
    geogecko Well-Known Member
    Broken Arrow, OK
    Screw driver makes this look a lot easier. Thanks for the pictures.
    Is it advised to replace the idlers/tensioner as preventative maintenance? From what I've found, the tensioner looks like a PITA to swap out.
    Going to do this soon, as I have 118k miles, and haven't touched the belt.
  7. Feb 10, 2013 at 4:37 PM
    geogecko
    Broken Arrow, OK
    Did mine this weekend, not a piece of cake, but only took about 30 minutes or so. Already had the skid plate off, replacing the front struts, so thought I might as well do this while I was at it. I used a 5mm allen key to stick in the slot to hold the tensioner while replacing the belt, also followed the advice in the shop manual about doing the P/S pump last, and worked pretty well. Only weird thing, was realizing that you have to slide the belt over the fan to remove/install. I also did the trick to just barely turn the ignition to see if everything is lined up before ruining the belt. Went just fine the first time.
    Even at almost 120k miles, the old belt...shows no signs of wear. No cracks or missing ribs or anything...but better safe than sorry.
    SAR Taco likes this.
  8. Feb 11, 2013 at 10:34 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    You did the right thing. Look at this. The new belts don't show cracks or wear.
    https://www.youtube.com/watch?v=ck8HollJYOc
  9. Feb 11, 2013 at 11:17 AM
    geogecko
    Broken Arrow, OK
    Wow, great post! Never would have thought to use a gauge like that to check the wear. So you really can't go by the old standards anymore. Glad I did it. May have explained some idle inconsistencies I've noticed once in a while. We will see.
  10. Feb 11, 2013 at 12:57 PM
    george3
    New Jersey
    Hey George, glad you could use the information - from another George.
  11. Feb 11, 2013 at 1:10 PM
    geogecko
    Broken Arrow, OK
    LOL, thanks, but not George. Jason, actually. Kind of a weird name I picked up a long time ago when I was really interested in geocaching, and it just stuck. It's not the first time though! :p
  12. Feb 11, 2013 at 1:46 PM
    george3
    New Jersey
    I guess I got a little dyslexia - didn't notice the r was missing. :eek:
  13. Feb 11, 2013 at 3:45 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  14. Feb 12, 2013 at 9:22 AM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    Working on this right now, first time changing my belt on a 2nd gen Yota, 1st gen 5VZE belts... were a just a little more technical than this. Thanks a ton for the photos, even helped me put the right craftsman screwdriver to use.. nice choice!
  15. Sep 2, 2013 at 1:36 PM
    #35
    hondamxracer
    hondamxracer Well-Known Member
    Thanks for the pics! Just changed mine.
  16. Jul 3, 2014 at 12:56 PM
    #36
    JcTacoma
    JcTacoma Well-Known Member
    TONY
    909
    06 TACOMA OFF ROAD
    Which way do you turn with the ratchet
  17. Jul 3, 2014 at 1:04 PM
    #37
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Subbed
  18. Jul 3, 2014 at 1:17 PM
    #38
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    My truck has a belt diagram posted on the inside of the hood....
  19. Aug 30, 2014 at 1:21 PM
    #39
    Crom
    Nick
    San Diego, CA
    Millions
  20. Sep 20, 2014 at 11:24 AM
    #40
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Maybe I'll get to this today or tomorrow. Certainly looks a lot easier than the belt I did on my old Grand Am. Anyone recommend a belt? Or any generic belt fine?
